Author Topic: Cambelt DVD  (Read 3812 times)
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: Cambelt DVD
« Reply #15 on: 06 January 2009, 11:47:51 »
Just to confirm which DVD - V6 or 2.2 etc - pushing you luck if both ;D
If you transfer money bank charges  will be more than DVD cost >:(
Hi,
My car is a 2000 Opel Omega 2.6 V6, I'm pretty sure it's an Omega B, but definitely V6 2.6L.
The transfer would be from a UK account so no heavy charges, but yes if I was transferring from here in SA the charges would be more than the cost.
Cheers
Brad
Is the 2.6 Cambelt change same as the 2.5  :-?
« Last Edit: 06 January 2009, 11:48:22 by iggy21uk »
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
ians
  • Reading
Re: Cambelt DVD
« Reply #16 on: 06 January 2009, 12:01:10 »
Mostly, although I suspect the 2.6 has the same fixed lower idler as in the 3.2.   There are posts about this on the forum,  and I think one of the differences is you route the belt anticlockwise from the crank, rather than clockwise as usual and in the dvd.   But all this with the proviso that I have never done it...
jjleonard
  • stevenage
Re: Cambelt DVD
« Reply #17 on: 06 January 2009, 13:37:06 »
I've done a 2.6 cambelt change following the DVD, and apart from the lower idler being fixed (i.e. not adjusted to 3 o'clock as per the DVD, if I understand it correctly), it was straightforward. I routed the belt clockwise without any problems.
The only thing you need to be aware of is setting the timing - because you can't adjust the lower idler, the job may require a few more goes to get everything timed up properly (the whole job took me about 4 hours - my first ever cambelt).
Brad Woolley
  • Johannesburg South Africa
Re: Cambelt DVD
« Reply #18 on: 06 January 2009, 14:46:42 »
Hi Guys,
Thanks for the advice, I've a couple of mates who work with Opels regularly, it's just the Omega isn't that common here.
Someone told me the 2.6 is very similar to the Isuzu (Vauxhall) engine fitted in the Frontera (Frontier here), any one any comments ?
Brad
iggy21uk
Re: Cambelt DVD
« Reply #19 on: 06 January 2009, 19:41:33 »
I have'nt forgot, got a problem - unable to get into shop at the mo?
Brad Woolley
Re: Cambelt DVD
« Reply #20 on: 06 January 2009, 19:57:57 »
Hi,
No problem, our shipment won't leave Heathrow till the 16th at the earliest, might even be a week later.
Cheers
Brad
iggy21uk
Re: Cambelt DVD
« Reply #21 on: 06 January 2009, 22:40:38 »
My logging into shop sorted - DVD ordered.
Brad Woolley
Re: Cambelt DVD
« Reply #22 on: 07 January 2009, 07:02:45 »
Thanks Ian, It's really appreciated.
On another point a Haynes manual was on my shopping list, but I see on Haynes site the Omega 2000 on is not available yet, any guys recommend an alternative for the Omega B 2000 V6 2.6 ??
Brad
Brad Woolley
Re: Cambelt DVD
« Reply #23 on: 17 January 2009, 07:53:40 »
HI,
 My shipper reports having received a DVD, it should be on this weekends flight, with luck I'll get it Tuesday.
 A big thanks for that, and anything I can do to return the favour please feel free....
Cheers
Brad
