Author Topic: Help with wedding photos  (Read 6658 times)
Bo Bo
  • Coventry
Re: Help with wedding photos
« Reply #15 on: 10 January 2007, 20:12:39 »
If you're graphics card and monitor can cope, push the resolution as high as it'll go (1600x1200 or higher) and then screendump them.  If all you're after doing is a smallish album then you can just about get away with it....
...as for cracking the exe then I'd expect the program to downsize the originals to pack them anyway, so I'd be suprised if there were any hi-res versions lurking in there.
Found a prog called RestorePTE & it works pretty well, saves the pics as bitmap somewhere between 2 & 3 MB.
« Reply #16 on: 10 January 2007, 20:23:50 »
Is that the answer to your problem? Or is quality still too low?
Bo Bo
  • Coventry
« Reply #17 on: 10 January 2007, 21:14:06 »
They look pretty good on the PC but don't know what the original sizes are.
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
« Reply #18 on: 10 January 2007, 21:36:35 »
The person who took the pictures may have copyright ???????
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Martin_1962
« Reply #19 on: 10 January 2007, 22:13:12 »
Grey area here!
1) They paid them
2) They are on them
BUT
3) They took them
I'd say 70-30 towards justifiable copying
Bo Bo
  • Coventry
« Reply #20 on: 10 January 2007, 23:14:00 »
Grey area here!
1) They paid them
2) They are on them
BUT
3) They took them
Yes it is, if a carpenter builds you a cupboard do you have to pay him every time you open the door?
    • E250 Est / Elroq
« Reply #21 on: 11 January 2007, 08:11:54 »
Photographers generally keep the copyright, even though you commissioned them.
Some will however, sell you the images, some at a cheap cost, some rediculous, got to be worth a phone call asking.
I very much doubt you will get any pictures out of the program, except using the print screen trick.
probably made using Photodex Proshow Gold, lots of proffessional photographers use this or similar.
« Last Edit: 11 January 2007, 08:13:50 by jimbob »
nixoro
  • Hitchin, Herts
« Reply #22 on: 11 January 2007, 08:52:54 »
Having limited knowledge of photo disks my suggestion may or may not work.
I had a kodak photo cd created and I was able to browse it using powerpoint it seemed to break down the slideshow so to speak so I could pick what I wanted.
Used normally it was a slideshow.
You maybe able to select the exe file from within the program and open it this way it should show all the slides.
This maybe worth a look. :-/
snappa
  • London
  • when`s payday
« Reply #23 on: 11 January 2007, 13:21:47 »
Hi Bo Bo
 most photographers tend to use Adobe photoshop, it is supposed to be the muts manhood. its very complicated but can do almost anything with digital images. pm me with your address & a contact no. & I will see what i can do :y
Bo Bo
  • Coventry
« Reply #24 on: 11 January 2007, 14:41:33 »
Cheers I'll give it try when I get home :y
Bo Bo
  • Coventry
« Reply #25 on: 11 January 2007, 14:43:26 »
Hi Bo Bo
I have a err.... "copy" of Photoshop but don't currently have it installed, if all else fails I'll give it a go, cheers.  ;)
