Author Topic: Sunroof switch bulb  (Read 1425 times)
Dazzler
  • Haverhill, Suffolk
Sunroof switch bulb
« on: 15 January 2009, 15:33:35 »
Mine is removeable, but does anyone know if it is available to buy on its own, or is there an aftermarket one that is known to fit???
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Sunroof switch bulb
« Reply #1 on: 15 January 2009, 15:39:04 »
Yup you can get the bulbs on their own from the stealers.
90512802 BULB, SUN ROOF MOTOR, 12V/1.2W
TuBy's new whipping boy.
nixoro
  • Hitchin, Herts
« Reply #2 on: 15 January 2009, 15:46:43 »
Do these just twist or pull out somehow tried to take mine out previously to replace and the thing wouldn't budge :-[ :)
Dazzler
« Reply #3 on: 15 January 2009, 15:59:06 »
The switch just pulls off, but is hard.
Then remove the interior light assy and disconnect.
Then remove 2 screws which are now revealed.
remove the manual crank plastic infil panel.
Pull down on plastic housing from the front.
The rear has 2 clips which will let go when you pull the front down.
Pull front down all the way as the panel needs to be at 90 degrees to let go at the rear.
Before you pull down you need to unclip the rotory switch from the main plastic housing.
HTH
Dazzler
« Reply #4 on: 15 January 2009, 20:49:39 »
Thankyou kind sir :y
STMO123
« Reply #5 on: 15 January 2009, 21:39:40 »
HTH
I'd have done without the bulb :o :o ;D
Dazzler
« Reply #6 on: 15 January 2009, 21:41:52 »
HTH
Its quite easy when you know how ;)
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #7 on: 15 January 2009, 21:52:41 »
HTH
You did you bought an ashtray. ;D
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #8 on: 19 January 2009, 17:21:17 »
I changed the bulb in mine at the weekend just a question is the switch meant to be just floating about in the black box  :question it does in mine I could not see how it was meant to be fixed if not  :exclamation . Anyway its all back together and working ok .
But the illuminated switch is taking time to get used to just seems odd having it lit up  ::)
Dazzler
« Reply #9 on: 19 January 2009, 18:31:31 »
The switch clips into the large plastic surround under the knob itself, when not clipped in then it is free to float around a bit.
HTH
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #10 on: 19 January 2009, 21:31:17 »
With mine i has a clear plastic surround after the knob is revomed , I can not seem to remove this any tips. :question.
Not sure if the facelift has any diff set up mine has not worked for the past 18 months.
Thanks
Steve
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #11 on: 19 January 2009, 21:33:00 »
Thanks
Steve
Pity you didn't mention it yesterday Steve, our Tony would have shown you how to get at it as he did mine.
LFF64
  • HADDENHAM BUCKS
« Reply #12 on: 19 January 2009, 22:01:10 »
 ;) thats ok then thanks fort that  :y
