Author Topic: Qantas gripe sheet  (Read 839 times)
chrisl_1960
  • cambs
  • why didnt I get a V6
Qantas gripe sheet
« on: 27 January 2009, 21:37:41 »
 Remember it takes a college degree to fly a plane but only a high
 School diploma to fix one.
After every flight, Qantas pilots fill out a form, called a "gripe Sheet," which tells mechanics about problems with the aircraft.
The mechanics correct the problems, document their repairs on the form, and then pilots review the gripe sheets before the next flight.
Never let it be said that ground crews lack a sense of humour.
Here are some actual maintenance complaints submitted by Qantas'
Pilots (marked with a P) and the solutions recorded (marked with an S) by maintenance engineers.
By the way, Qantas is the only major airline that has never had an accident.
     P: Left inside main tyre almost needs replacement.
     S: Almost replaced left inside main tyre.
     P: Test flight OK, except auto-land very rough.
     S: Auto-land not installed on this aircraft.
     P: Something loose in cockpit.
     S: Something tightened in cockpit.
     P: Dead bugs on windshield.
     S: Live bugs on back-order.
     P: Autopilot in altitude-hold mode produces a 200 feet per minute Descent.
     S: Cannot reproduce problem on ground.
     P: Evidence of leak on right main landing gear.
     S: Evidence removed.
     P: DME volume unbelievably loud.
     S: DME volume set to more believable level.
     P: Friction locks cause throttle levers to stick.
     S: That's what they're for.
     P: IFF inoperative.
     S: IFF always inoperative in OFF mode.
     P: Suspected crack in windshield.
     S: Suspect you're right.
     P: Number 3 engine missing.
     S: Engine found on right wing after brief search.
     P: Aircraft handles funny.
     S: Aircraft warned to straighten up, fly right, and be serious.
     P: Target radar hums.
     S: Reprogrammed target radar with lyrics.
     P: Mouse in cockpit.
     S: Cat installed.
     And the best one for last..................
P: Noise coming from under instrument panel. Sounds like a midget Pounding on something with hammer.
     S: Took hammer away from midget.
Re: Qantas gripe sheet
« Reply #1 on: 27 January 2009, 21:40:52 »
The old ones are the best :y :y :y :y :y
Funny though ::) ::) :y :y
chrisl_1960
  • cambs
« Reply #2 on: 27 January 2009, 21:43:50 »
found it in an old folder on PC, made me smile again so thought I'd share it  :y
Ken T
  • Stockport
« Reply #3 on: 27 January 2009, 22:11:24 »
It surprising the number of jokes about planes appearing, now I fly home at the weekends !. Fortunately none about Jet2 yet  :-/
Ken
