Author Topic: Changed my LNB for a quad output but..........  (Read 1360 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
« on: 31 January 2009, 16:17:04 »
lost BBC1, BBC2 and Channel 4.  Still have all the other channels and the recording 2 channels at once thingy now works.
Did all the usual resets, updates, signal tests (got a v good signal) but just cant get those channels to work.  Popped the old one back on and I get them again....v strange!
Any experts out there know whats going on?  (Im in Europe.....shhhh)
Re: Changed my LNB for a quad output but..........
« Reply #1 on: 31 January 2009, 16:32:11 »
I did the same thing about 6 month ago but it worked straight away so don't know.
Martin_1962
« Reply #2 on: 31 January 2009, 18:11:37 »
What size dish do you have?
Have you got the same azimuth on the new LNB?
BBC are on a tighter footprint than some other channels.
Why shh? Can't think of any problems
Gaffers
« Reply #3 on: 31 January 2009, 18:21:48 »
About 80cm
Come again?  :-?
This is my worry but the other LNB works fine so surely this one should?
Sky will cancel your contract if they find out you are outside the UK.  I have to call them through Skype so as not to show my German number  ;D ;D ;D ;D
Martin_1962
« Reply #4 on: 31 January 2009, 20:55:51 »
About 80cm
Mine is 65cm
Come again?  :-?
Angle of the LNB on the dish
See above
Ah Sky - I was thinking Freesat
« Last Edit: 31 January 2009, 20:56:39 by Martin_1962 »
gwa
  • Peterborough
  • Ginger With Attitude
« Reply #5 on: 01 February 2009, 06:12:10 »
How does it come? with Tonic or Coke?  ;D or is it a posh Schnapps?  :y
« Last Edit: 01 February 2009, 06:13:44 by gwa »
If it ain't fun, it ain't worth doin
Smalley
  • Chichester  W. Sussex
« Reply #6 on: 01 February 2009, 09:55:52 »
Think that the skew on the LNB may be wrong, check on www.dishpointer.com for confirmation. Wrong skew causes loss of some transponders.
Martin_1962
« Reply #7 on: 01 February 2009, 11:03:55 »
PErhaps its that - it is what I meant anyway
Gaffers
« Reply #8 on: 01 February 2009, 15:27:23 »
see you're being too clever again!!  ;D ;D ;D ;D ;D ta bud  :y
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #9 on: 01 February 2009, 16:04:27 »
If you know how to get into the "secret" installers menu check in lnb set up that the 22KHz Command is set to on  :y
Proz
« Reply #10 on: 02 February 2009, 18:41:06 »
Any luck fixing it yet ??
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #11 on: 02 February 2009, 18:59:41 »
LNB Horizontal / Vertical posistioning is incorrect! try twisting the lnb sideways about 30 degrees the BBC & C4 services are broadcast in a H signal as  opposed to a V signal or its the otherway round  but try what i said and report back :y
BBC & C4 & ITV are also relayed of Hotbird 13E if thats any interest the channel frequancies are at www.lyngsat.com
« Last Edit: 02 February 2009, 19:01:50 by tmx »
Gaffers
« Reply #12 on: 02 February 2009, 19:49:25 »
I think I know what has caused the problem.  My dish is a european dish with a european LNB.  I ordered an LNB from teh UK.  Apparently the LNB skew angles are different, not so much for the majority of channels but for those which it matters, BBC and C4, its enough.  I am waiting for a European LNB to come through now to see if I was correct.
I will post the results  :y
Page created in 0.032 seconds with 16 queries.
