Author Topic: Range Rover Engine V8  (Read 2582 times)
Ned Kelly
  • Salisbury
« on: 08 February 2009, 19:07:27 »
Hi guys,anyone know of the best size engine to go for as I have a choice of 4.0/4.4/4.6. presumably the bigger the cc the thinner the walls,and there lies a potential problem.
Thanks
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Range Rover Engine V8
« Reply #1 on: 08 February 2009, 19:20:57 »
If I remember correctly they had problems with the 4.6 as it was bored to the engines limit I read on a Range Rover forum when we had them.
« Reply #2 on: 08 February 2009, 19:24:18 »
There is a porous block problem with one of those varients - not sure which though.....
« Reply #3 on: 08 February 2009, 19:29:26 »
They are all the same bore (94mm), its the stroke thats different.
Porous, no not really.
The 94mm blocks do have more isues with liners dropping than the 89mm (of 3.5 Fame).
« Reply #4 on: 08 February 2009, 19:31:25 »
Should have added, age is a key thing here to as the block design chnged around 93ish
Whats the application?
« Reply #5 on: 08 February 2009, 19:51:09 »
I have to ask, where is the 4.4 engine coming from as these were only ever in production in oz unless its a 3.5 with a stroker kit fitted!
For info
4.0 (its actualy a 3.95 litre engine and the same capacity as the earlier 3.9 units) - 190 Bhp - 320Nm torque
4.6 - 225 Bhp - 380Nm torque.
« Last Edit: 08 February 2009, 19:53:11 by Mark »
iainb
  • West Midlands
« Reply #6 on: 08 February 2009, 19:54:00 »
Maybe latter RR with BMW  4.4 petrol
« Reply #7 on: 08 February 2009, 19:54:33 »
Possibly.....a VERY different beast though
iainb
  • West Midlands
« Reply #8 on: 08 February 2009, 19:55:58 »
Mated to a GM 5 speed box
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #9 on: 08 February 2009, 19:56:03 »
For info
i have to laugh, i can get both more power and torque out of my 2.4t after remapping and have nearly the same power as standard :P
V8!!!!
« Reply #10 on: 08 February 2009, 20:03:34 »
For info
Yes but, you will get a peeky horrible over blown delivery of power as a result.....the V8 would beat it in the same chassis with ease.
Remember also that the figure is that as delivered from the factory with no mods
ngrainqey
  • rotherham
« Reply #11 on: 08 February 2009, 20:08:34 »
For info
it's actually quite a good power delivery, the turbo comes in at 1800 revs so is there from about the revs you setoff on to when you change gear and fades towards 4000 revs
plus its 5 cylinders so really quite smooth!
the volvos 200bhp and 285nm as standard
V8!!!!
« Reply #12 on: 08 February 2009, 20:10:39 »
For info
Makes no odds....wind up a turbo and you compress the torque delivery curve.....
Further to this, below the point where the turbo spins you get little go, this is for two reasons
1) A restricted inlet setup due to the addition of a turbo, intercooler and miles of pipes
2) Lower compression ratio.
A car with the V8 lump would be way ahead and probably slipping int second before your boost had even arrived!
Physics mate.....its a bugger!
bertiecbx550
« Reply #13 on: 08 February 2009, 20:19:02 »
Are you sure your not Mr Scott in disguise???? :o :o
    • 530D M Sport, 330i Coupe
« Reply #14 on: 08 February 2009, 20:21:18 »
There's no substitute for cubic inches....
