Author Topic: Flashing sports light on senny  (Read 912 times)
bighed
  • Shropshire
« on: 11 February 2009, 16:03:24 »
Light flashed yesterday straight away after starting up, I turned car off and back on again and all was well. Been told it could be due to a gearbox fault and need it testing. Is there a way to paperclip a senny at all?  :y
Re: Flashing sports light on senny
« Reply #1 on: 11 February 2009, 16:08:47 »
Yes!
But I'm at work and so don't have the web site with the relevant info. Ask on the ABS forum though & you'll get an answer.
You can 'paper clip the engine, gearbox, alarm, digi dash, ride control suspension.
bighed
  • Shropshire
« Reply #2 on: 11 February 2009, 17:53:09 »
Yes!
Got member pack through 2 days ago and still waiting to be activated!!!
Thanks for info tho andy!!!  :y
Iain
« Reply #3 on: 11 February 2009, 18:00:32 »
Yip paper clip it,under the bonnet,drivers side turret if i mind right,next to the fuel change switch....and count the flashes
I would source a gearbox ECU mate,common problem with them.....
Iain
« Reply #4 on: 11 February 2009, 18:01:53 »
On another point mate,join the Total Carlton forum,as good as this one and most things are relevent to Senny's,a lot of good guys there too :y
« Reply #5 on: 11 February 2009, 18:07:24 »
The VXON info for the cav will tell you which pins to short out.
« Reply #6 on: 11 February 2009, 18:13:22 »
vaguely remember mine doing this and it turned out to be a relay in the relay box in the engine bay,dont remember which one though,it was a long time ago. :-/
bighed
  • Shropshire
« Reply #7 on: 11 February 2009, 19:08:53 »
All info taken in. Thanks guys  :y
Page created in 0.062 seconds with 16 queries.
