Pages: 1 ... 7 8 9 10 11 12 13 [14] 15   Go Down
Author Topic: OOF Showplates  (Read 19666 times)
nick v6
  • walsall / west midlands
Re: OOF Showplates
« Reply #195 on: 13 February 2009, 16:33:47 »
they don't look that bad in my opinion and ann has said the same
unless your going to use solid plastic you aint gonna get them perfectly flat
they look sound
see what everyone else thinks but i think top stuff you've done a grand job :y :y :y :y
richardirv
  • Leeds, West Yorkshire
    • Omega 2.6 MV6 2002
Re: OOF Showplates
« Reply #196 on: 13 February 2009, 16:44:08 »
Cheers bud, you'd of laughed today, me stood in my kitchen ironing laminated number plates!! I even melted 2 by accident. Gotta re-do them!! LOL
nick v6
Re: OOF Showplates
« Reply #197 on: 13 February 2009, 16:46:41 »
i got about 3 loads of washing that needs ironing
do you want to do them as well ;D
your doing a spot on job
when the plates have been sent out to the people that have ordered them we should open a new thread soley for pictures of cars with the plates on :y
Re: OOF Showplates
« Reply #198 on: 13 February 2009, 17:23:18 »
I'm lead to believe that the reason the laminated stuff "curls" is a slight difference in temperature between the top and bottom sheets, one contacts the hot roller, the other doesn't, so they end up slightly different.
Apparently, one way of sorting this is to send the item back through the other way up ... this means that both sides have had a "hot + cooler" run and they end up flat.
This came from a guy who does commercial printing and a fair bit of laminating for a living, I have no knowledge or proof that it works .... if you have a "spare" laminating pouch it might be worth a try ???
richardirv
Re: OOF Showplates
« Reply #199 on: 13 February 2009, 17:36:47 »
My laminator has a switch for 150micron and 250micron. The laminates used are 250. would it be safe to put the ones already laminated back though or would it cause meltdown? I may test one on the 150 setting but twice through but there isn't much I can do about the ones already done!!
Re: OOF Showplates
« Reply #200 on: 13 February 2009, 17:58:52 »
Can't answer and he's left work .. :(  been playing with my cheapy laminator ... putting through twice on "high" does not cause melting.. as I left it until almost cold by the time it goes back in .. so it never gets that hot. On an A4 sheet it does seem to make a difference to the curl .. but its hard to tell as A4 doesn't curl that much anyway .. :(
HTH
richardirv
Re: OOF Showplates
« Reply #201 on: 13 February 2009, 18:03:17 »
Ok thanks for the info, just don't want to wast to many of these A2 pouches as they are not cheap!!  :y
Welung666
Re: OOF Showplates
« Reply #202 on: 13 February 2009, 18:15:01 »
I'm sure I'd already said that!!!!!!
richardirv
Re: OOF Showplates
« Reply #203 on: 13 February 2009, 18:16:31 »
Yes you had bud, I was just unsure if to put them through twice the heat had to be lower on each pass or full heat on both pass's, if you know what I mean  :y
richardirv
Re: OOF Showplates
« Reply #204 on: 17 February 2009, 07:20:11 »
Ok envelopes arrived yesterday! Its a tight fit but should be fine!!  :y
I am going to send 1 set today so I can gauge the postage costs.
So who wants to be first?  :D
nick v6
Re: OOF Showplates
« Reply #205 on: 17 February 2009, 07:22:30 »
ready when you are mate
let me know how much
can you get mine and tigra ann's in the same envelope
richardirv
Re: OOF Showplates
« Reply #206 on: 17 February 2009, 07:25:28 »
I will try chief, I only tried one in last night and it is tight!
« Last Edit: 17 February 2009, 07:26:09 by richardirv »
nick v6
Re: OOF Showplates
« Reply #207 on: 17 February 2009, 07:26:53 »
if it two envelopes dont worry use two envelopes
let me know how much ill be online most of the day
how do you need the money
paypal or cash
richardirv
Re: OOF Showplates
« Reply #208 on: 17 February 2009, 07:28:34 »
Think paypal will be easiest!
nick v6
Re: OOF Showplates
« Reply #209 on: 17 February 2009, 07:31:38 »
no problem buddy
let me know what i o you
money has been sitting in paypal for you for a while now :y :y
Pages: 1 ... 7 8 9 10 11 12 13 [14] 15   Go Up
