Author Topic: Laptop question  (Read 1742 times)
Laptop question
« on: 16 February 2009, 23:44:34 »
Can I plug my laptop into the car for power?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Laptop question
« Reply #1 on: 16 February 2009, 23:47:00 »
With the right adapter yes.
TuBy's new whipping boy.
Re: Laptop question
« Reply #2 on: 16 February 2009, 23:51:29 »
Thanks, will go and have a look on ebay :y
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Laptop question
« Reply #3 on: 16 February 2009, 23:55:21 »
I got one for my old laptop but I haven't tried it with the new one.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Laptop question
« Reply #5 on: 17 February 2009, 00:18:50 »
Well it has to have a plug compatible with your lappy, be able to select the voltage you need and provide enough amperage to run your lappy.
Voltage and current is usually marked on your AC adapter.
Which just leaves the question of wether they supply a plug that will fit.
Re: Laptop question
« Reply #6 on: 17 February 2009, 00:21:26 »
Thanks, will look further into that, made a mistake of buying a general charger in the past to power a video camera, that was not powerful enough. :)
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
Re: Laptop question
« Reply #7 on: 17 February 2009, 00:24:23 »
The one you found isn't powerful enough to run my lappy for instance but as they say your mileage may vary.
Think this is the same as mine.
Clicky
Re: Laptop question
« Reply #8 on: 17 February 2009, 00:27:30 »
Clicky
Thanks, will look further into this. :y
Re: Laptop question
« Reply #9 on: 17 February 2009, 09:38:34 »
The other thing you could do it get a little mains inverter and use the power supply that came with the laptop. Got a nice little one from Maplins recently for 20 quid. 150 watt IIRC.
Tommy
  • Truro, Cornwall
Re: Laptop question
« Reply #10 on: 17 February 2009, 10:36:05 »
I've used one of these for a couple of lappy's - work well and come with a variety of adapters
http://www.igo.com/
« Last Edit: 17 February 2009, 18:39:33 by tomlusc »
Re: Laptop question
« Reply #11 on: 17 February 2009, 11:11:18 »
As Kevin suggests, consider one of these,
http://www.maplin.co.uk/Module.aspx?ModuleNo=48723
Re: Laptop question
« Reply #12 on: 17 February 2009, 11:37:42 »
That'll do the job. Mine is the 150W one, which is now 40 quid. :-?
You won't get anywhere near 300 watts out of a cigar lighter socket before the fuse blows, of course, but for powering a laptop it'll be more than adequate.
Re: Laptop question
« Reply #13 on: 17 February 2009, 11:40:27 »
You'll also get a more consistent supply from an inverter (so I'm led to believe) as the ciggie socket can give spikes  :y :y :y
Re: Laptop question
« Reply #14 on: 17 February 2009, 12:03:15 »
No difference as the adaptor wil have a DC-DC converter.....and the inverter has a DC-AC converter.
« Last Edit: 17 February 2009, 12:03:36 by Mark »
