Author Topic: Interesting - Cam profiles  (Read 1397 times)
« on: 20 February 2009, 14:53:55 »
Did a quick measurement on the A and G cams out of a 3.0 V6.
The profiles are as follows:
You will note that the G cam has the same lift but has a longer duration!
Not much difference other than that!
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Re: Interesting - Cam profiles
« Reply #1 on: 20 February 2009, 14:55:32 »
The question is how much of a difference that would make  :-/
« Reply #2 on: 20 February 2009, 14:57:56 »
Quite a bit on the inlet, much less so on the exhaust
M0T0RVATE
  • Orpington
    • 94 Omega Elite Saloon 3L
    • MOTORVATE STUDIO
« Reply #3 on: 20 February 2009, 15:00:58 »
Longer duration is better than more lift.
Too much overlap though will result in very 'lumpy' idle speed, and an 'unsociable' drive at low mph.
Colin
Martin_1962
« Reply #4 on: 20 February 2009, 15:50:37 »
2.6 cams now and then all 4 please
Timbuk
  • Telford
  • owned a Datsun 120y once!
« Reply #5 on: 20 February 2009, 16:29:14 »
Only interesting if i had a rather clue what that means :D :D and dont you lot pretend im the only one who hasnt got a clue ;D ;D
« Reply #6 on: 20 February 2009, 16:33:17 »
Elementary, the G cams hold the valve open longer.....and hence more air can get in easier
« Reply #7 on: 20 February 2009, 16:58:25 »
I consider it like necking my favourite nectar...  ...the longer and wider my gob is open, the more efficiently the glass is ready for the next....
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #8 on: 20 February 2009, 17:16:05 »
Fancy not understanding, tut, tut.
 :o
I like red cars
Timbuk
  • Telford
« Reply #9 on: 20 February 2009, 17:22:39 »
 :o
At least im not pretending i do ;D ;D
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #10 on: 20 February 2009, 17:38:52 »
 :o
It's quite obvious from the graph ::)
I like red cars
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
« Reply #11 on: 20 February 2009, 17:58:28 »
vtec is the way forward best thing since sliced bread,, dont rate the vvt system tho
