Author Topic: The best to buy ? 2.2 2.6 3.0 3.2 ?  (Read 2896 times)
Sylvester
« on: 19 February 2009, 00:35:23 »
Hi
I’m planning to sell my 2.0 '98 gels is just getting a bit old.
Would like to buy a 2001 -2003 model but don’t know witch one should I get.
I’m thinking about 2.2 petrol 2.2 diesel or 2.6 , 3.2 petrol.
The best one, the most reliable one would be??
Regards
Sly
Re: The best to buy ? 2.2 2.6 3.0 3.2 ?
« Reply #1 on: 19 February 2009, 00:36:45 »
Hi
Regards
Sly
Unfortunately this is one which is down to personal choice... For me it's V6 every time ::) ::) ;D ;D :y :y
« Reply #2 on: 19 February 2009, 00:41:44 »
V6 for me also.   :y :y
« Reply #3 on: 19 February 2009, 08:33:43 »
I would say it would be down to personal preferences, they're all fairly reliable if well maintained. I would buy the top spec 3.2 Elite, more toys than an Anne Summers shop and it can move as well :)
Sad
  • Dorset
    • VW Golf
« Reply #4 on: 19 February 2009, 08:41:48 »
I'd stick with the V6s too...  And if possible, an Elite    :)
« Reply #5 on: 19 February 2009, 09:21:45 »
the 2.2 cant be papercliped which counts that out for me. So only leaves a v6, and if your going to do that may as well go the whole hog with a 3.2 elite, if you can find one. Just be aware drive by wire and coil packs are more expensive than the throttle cable and leads/ dis set up on the 3.0. But on the other hand the 3.2 has no egr, no secondary air and is a bit easier to work on  (imho). 2.6 is the same drive by wire engine.
Haveing owned a 2.5 and now a 3.2 the difference in performance is marked, for example with a constant throttle mid corner you can jab the pedal and play with the rear end as the power responds, no real response at all when you do that on a 2.5 by
comparisson. It really does shift for a big road car on the motorway.
cam2502
  • dumfries,scotland
    • 08 BMW 520d & 03 Saab 95
« Reply #6 on: 19 February 2009, 11:17:00 »
i've a year 2000 2.5 v6 elite, love it! you gotta go for the elite mate. :y
Dusty
  • Shropshire
  • Erotic Romance Author
« Reply #7 on: 19 February 2009, 12:07:28 »
V6 only in my view. :-* :-*
mkaminski100
  • Basingstoke
« Reply #8 on: 19 February 2009, 12:35:28 »
comparisson.
Because of the higher diff ratio in 3.2.
For me 4 pot models are only good with manual gearbox. Otherwise it's just too slow and petrol consumption is to high.
V6 are ok, same 2.6 and 3.2. These are more expensive to service than 2.5 and 3.0 (and less spares available on the market due to production only within 2 years).
3.2 have a cat problems which not occur in 2.6.
new engines and autoboxes are smoother and more quiter than old ones.
If you find a decent ELITE, go for it, but many CDXes have most of ELITE's toys and can cost less.
Apart from that it's your preference.
« Reply #9 on: 19 February 2009, 14:33:23 »
comparisson.
Surely if it was higher geared it would reduce the responsiveness?.. or are you saying it has a (numerically) higher diff ratio ( = lower geared?).
I certainly wouldn't want a 2.5 that's higher geared than my 3.2.  :o As it is my 3.2 is doing 26 MPH/1,000 RPM. I think I can live with a car that's geared for 156 MPH @ 6,000 RPM.  ;D
This link http://www.omegaowners.com/forum/YaBB.pl?num=1163895466 suggests that the 2.6 is lower geared (4.22) than the 3.2 (3.9) which is what I would expect. Surely the 2.5 would have the 4.22 diff as well?
(BTW: I'm talking autos here. The manuals are different.)
mkaminski100
  • Basingstoke
« Reply #10 on: 19 February 2009, 14:53:27 »
I am always confused with high low geared. With same revs, 2500 for ex,  3.2 will doing like 65, while 3.0 will do 70. And it’s diff, not the gearbox ratio! All 4L30E autoboxes have the same ratio.
Sylvester
« Reply #11 on: 19 February 2009, 15:43:41 »
Thx 4 helping !
Not sure yet , but looking  closer at the  Elite model's  !
Regards
Sly
« Reply #12 on: 19 February 2009, 15:45:03 »
 As it is my 3.2 is doing 26 MPH/1,000 RPM. I think I can live with a car that's geared for 156 MPH @ 6,000 RPM.  ;D .......
I know I harp on about Senators .....  ::) but overall my Omega is higher geared than the 24v Senator I had.  I can't think what speed/revs my Omega is but the Senator was 29mph per 100rpm in top gear (I do have an Auto Car from when Senators were new  ;)). I'm sure the Omega could have easily managed an overall figure of the same.
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #13 on: 19 February 2009, 17:38:57 »
personally i would try and go for either a 2.6 or 3.2...
I had a 2.5 elite and chopped it in for a 2.6 CDX, the 2.6 felt like a far better car with regards to performance and economy, some of that could have been due to the drive by wire set up that the later cars have, or maybe they are a better engine.
Spec, yes try to get an Elite, they have more toys and can be more desirable when resale time comes along
« Reply #14 on: 20 February 2009, 01:54:17 »
Just came back here as i forgot to mention the pre cat issue which causes the eml to come on. But i see you have mentioned it. But was not aware it only affects the 3.2. Is this correct? And if so why? Does the 2.6 not have pre cats?
