Author Topic: The dreaded RUST.....  (Read 2604 times)
jerry
« on: 21 February 2009, 16:21:32 »
Am I alone in finding that parts of my mig are increasingly attracting the dreaded rust? I bought my Sreg about a year ago and, at the time, apart from some very minor bits by wing mirrors, she looked very clean, with none noticeable on doors or arches. Obviously, some couldve been touched up for sale, but now have bits on bottom edges of both front doors, one on corner where bumper meets rear 1/4 panel by rear n/s wheelarch and several spots on 3 of 4 lower door panels (caused by stone chips?) plus the bits of bubbling by wing mirrors. At the moment there is still a fair bit of metal to rust ratio and (apart from bits by wing mirror) am getting others done next week at a cost of about £200. I know recent weather conditions havent helped esp with all the salt/grit on the roads, plus I live on the coast , but is this normal or am I just unlucky?? Love the car and am disappointed that dealing with rust will be an ongoing problem, esp as the jap import emina is 15 years old and has no rust at all (touch wood!)
        jerry :(
PS-the car is cleaned and waxed regularly, but any advice to help prevent further problems would be appreciated :y
vauxfan2k
  • Western Isles
Re: The dreaded RUST.....
« Reply #1 on: 21 February 2009, 16:26:54 »
Tip: If you are getting th top edges of the doors done, get the bodyshop to grease in behint the top lip, I did this on the 2 of my omega's and the rust hasnt returned.
Another place I find that they like to rust is on the inside of the rear doors beside the door catch mechanism, I dont know if its because like you Im by the sea, I also had this treated succesfully.
cheers  :y
jerry
« Reply #2 on: 21 February 2009, 16:30:57 »
Cheers,
have thought about using some spray grease on some of the more "hidden" surfaces, but guess will have to apply fairly regularly.
                                                            jerry :y
« Reply #3 on: 21 February 2009, 16:45:29 »
My W'reg is starting to go on the rear arches bottom of drivers rear door, inside rear door and it's washed regularly  :'(
SheWhoMustNotBeOUTBID
  • Drives the only front wheel drive miggy
« Reply #4 on: 21 February 2009, 17:07:02 »
My prized red Supermiggy is starting to have a bit of a problem with rust and I agree, it seems as if once it starts it is everywhere at once.
Save The Earth.., its the only planet with chocolate!!!!!!!!!!!!!!!
I wish admins were clever enough to remember to let me on the forum cause I do good coffee in return!
« Reply #5 on: 21 February 2009, 17:09:20 »
Vauxhall dont refer to it as rust,they call it "heritage". ;) ::) :)
jerry
« Reply #6 on: 21 February 2009, 17:30:14 »
Is THAT what they call it!!! :( ;D :( ;D
« Reply #7 on: 21 February 2009, 17:34:26 »
.....Rumour4 has it,they may be updating the terminology and renaming it IBD,(inbuilt bio degradation) :y ;D
jerry
« Reply #8 on: 21 February 2009, 17:45:29 »
very "green"of them I'm sure.....  ::)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #9 on: 21 February 2009, 23:08:47 »
Cheers,
                                                            jerry :y
This is good stuff  :y
http://www.mandp.co.uk/productInfo.aspx?catRef=901733
« Reply #10 on: 21 February 2009, 23:19:08 »
Another place I find that they like to rust is on the inside of the rear doors beside the door catch mechanism, I dont know if its because like you Im by the sea, I also had this treated successfully.
cheers  :y
This must be an ongoing problem, along with the rear window. In 1986 I got my 1984 company Cavalier estate resprayed under warranty, mind did leave a bottle of whisky in the glove compartment for the bodyshop manager to find, which he did. :y
jerry
« Reply #11 on: 21 February 2009, 23:33:35 »
cheers Turk, will look into this-could it be used on top of the paintwork on the relevant areas once theyve been treated and resprayed do you think?
dieseldean
  • chesterfield
« Reply #12 on: 21 February 2009, 23:47:05 »
when waxoiling do the inside of jacking points and crosmembers
mising bits like this annually is what made me scrap my 1st mig :'(
« Reply #13 on: 21 February 2009, 23:52:41 »
Why are we surprised, Vauxhall first learned this in the late 60 ::) ::) ::)
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #14 on: 22 February 2009, 00:11:23 »
It lasts for ages in sheltered areas like engine bay, boot, inside the door frames and sills etc.
Unlikely to be needed on properly treated and re-sprayed areas.
No problem spraying up under the top lip of doors as mentioned by vauxfan2k.
