Author Topic: CHKDSK won't run properly.  (Read 2232 times)
shyboy
  • Southport, merseyside.
    • Mazda 6
« on: 05 March 2009, 09:45:39 »
I've tried to defrag. my hard disk, but analysing this aborts due to 'inconsitencies in the file system'. It tells me to run' CHKDSK' which I've done successfully many times before. This time I'm getting a warning that 'F' parameters are not present and it's running in 'read only' mode. It checks through the file system but then simply disappears.
Being a computer ignoramus, I don't know what this means. Can anyone help me by explaining how I can get 'CHKDSK' to complete please? I'm using Windows XP Home, by the way.
Cheers,
Bill.
nick v6
  • walsall / west midlands
Re: CHKDSK won't run properly.
« Reply #1 on: 05 March 2009, 09:47:47 »
probly the best thing to do will be a fresh install of windows xp
sounds a much easier choice in my books
shyboy
    • Mazda 6
« Reply #2 on: 05 March 2009, 09:59:47 »
Hi Nick,
I don't even have enough savvy to attempt that I'm afraid. I really am useless with computers.
By the way, thanks for your phone nos. PM'd re. the CCTV thread. I will contact you if I get much further down that road.
Cheers,
Bill.
nick v6
« Reply #3 on: 05 March 2009, 10:01:48 »
Hi Nick,
Cheers,
Bill.
its quite straight forward to do a fresh install mate :y
Cybertrucker
  • Lichfield, Staffs
« Reply #4 on: 05 March 2009, 10:33:28 »
How are you running chkdsk?  From a command line (a black box within Windows with a prompt like C:\> at the start of each line), or from your hard drive's properties window in which you click a "Check now..." button?
http://www.cybertrucker.co.uk - Truck stuff
http://www.abd.org.uk - Association of British Drivers
My other car is a Granada.
My other other car is a Dennis.
shyboy
    • Mazda 6
« Reply #5 on: 05 March 2009, 12:58:08 »
Hi Fellas,
Thanks for your responses.
I simply click 'start' and type 'CHKDISK' into the 'run' box which displays when I click the 'run...' item in the menu. It's always gone through the whole procedure until now.
I ran a 'malwarebytes anti-malware' quick scan which came up with 5 instances of Trojan-Vundo which were then quarantined. Then ran it again almost immediately and it came up with just one instance of the same definition in 'System 32'. I'm sorry this doesn't mean much to me, but I'm concerned because I use internet banking.
If an item is quarantined, I presume it won't show up on a new scan, so the single item must be new, from where I don't know.
Taxi_Driver
« Reply #6 on: 05 March 2009, 13:01:45 »
Type 'chkdsk /f' in the window
the '/f' tells chkdsk to fix errors on the disk  :y
Taxi_Driver
« Reply #7 on: 05 March 2009, 13:07:19 »
e
Hi Fellas,
It would better to type 'cmd' in the 'run' box, this will open up a cmd window, where you can type 'chkdsk /f' . This will stop the window disapering once its completed so you can view the the results  :y
Tho doesnt sound good you have a virus and a rebuild maybe the best way to get rid if the AV software isnt getting rid for you
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #8 on: 05 March 2009, 13:07:46 »
Try hanging your drive off another Machine, on Boot up Xp will probaly do a chkdsk for you, if not run chkdsk in dos or windows on the doner PC for your drive.
Cybertrucker
  • Lichfield, Staffs
« Reply #9 on: 05 March 2009, 13:42:17 »
If you've got a virus which your AV isn't getting rid of then a re-install of Windows may be a good idea. Alternatively hand the machine over to a professional who may be able to chase down the virus and kill it completely.
Having said that, your problem with chkdsk may be that it can't get exclusive access to the drive because a lot of the files are locked because Windows is using them.  You might get on better with the following procedure:
  • Open 'My Computer'
  • Right-click on the C drive icon, and select 'Properties' on the menu which will appear
  • Click the 'Tools' tab
  • Click the 'Check now...' button, another little window will appear
  • Tick both the boxes and click the 'Start' button
  • You'll now get an error message saying that the check can't be performed because the utility needs exclusive access to the disk. (This could be the problem you're having doing it through the cmd box.)  It will ask you if you want to schedule the check for next time you start Windows, so click the 'Yes' button.
  • Restart your machine. Before it gets into Windows it will tell you that a disk check has been scheduled and give you ten seconds to abort it.  Don't touch anything, and chkdsk will start, the difference now being that as Windows isn't running chkdsk has got the whole disk all to itself and can do what it needs to.
« Reply #10 on: 05 March 2009, 18:34:27 »
use the /f parameter on command line, or Automatically Fix Errors in the GUI.
Either way, you should get an errro about unable to do as can't get exclusive use, and do at next reboot.
shyboy
    • Mazda 6
« Reply #11 on: 06 March 2009, 09:39:32 »
Panic over.
Thanks Cybertrucker! I followed your clear instructions and it sorted
everything out. A little bit more learned about these infernal machines.
As far as the Trojan-Vundo problem is concerned, I visited the MBAM Forum, (damn it! I've even started to use jargon,  ::)), and it seems the latest update had produced a 'false positive', reported by dozens of users. Not sure what that means precisely, but presumably it's a spurious identification of a problem. I'm assured that everything is now OK, and I'm currently running the latest updated version to check it's disappeared. Fingers crossed.
shyboy
    • Mazda 6
« Reply #12 on: 06 March 2009, 09:48:31 »
Yahoo! Scan completed, all clear.
Thanks for your help, guys.
Cybertrucker
  • Lichfield, Staffs
« Reply #13 on: 06 March 2009, 10:12:45 »
Panic over.
Glad to be of help!  :)  At least you've only got one computer to worry about - I'm responsible for over 200 of the wretched things on two sites five miles apart.  I knew I should have stayed a lorry driver...   ;)
« Reply #14 on: 06 March 2009, 11:06:36 »
Panic over.
Lightweight ;D
