Author Topic: Been Busy  (Read 1162 times)
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
Been Busy
« on: 06 March 2009, 14:54:11 »
Well i've been busy changing the camshaft sensor .... all was well till i removed the dis pack and suprise suprise i couldn't see the plugs for oil  :-/ ...... so i proceeded to do the breathers and cam cover gasket aswell as i had one anyway ...... what did suprise me was it was running quite well ( apart from my P0420 code ) . There was no misfire or any symptoms at all . Breathers were totally blocked  :o :o ... only one i couldnt get off was the small narrow one that was going to the throttle body ... couldnt get it of the cam cover  :-/ , i felt it would break if i tried to pull any harder , so i'll order a new one and change it ....cleaned everything with carb cleaner including the rubbers on the dis pack ... this is a big thing for me as im not good with cars and im quite pleased with myself for doing it without any problems and my working on cars confidence is growing now  :y...  going out for a run to test her now and hopefully should be ok  :y
bertiecbx550
Re: Been Busy
« Reply #1 on: 06 March 2009, 15:46:53 »
Feels good don`t it when you do sumat like that on your own you have a smile on your face wider than a cheshire cat.... ;D ;D
Dusty
  • Shropshire
  • Erotic Romance Author
Re: Been Busy
« Reply #2 on: 06 March 2009, 16:21:59 »
Well done Proz,you can hold your head high today. :-* :-* :-*
slb
  • elland
    • 99 2.5 v6 cdx
Re: Been Busy
« Reply #3 on: 06 March 2009, 16:25:56 »
 ;Dit does feel good to do it after a lot of swearing and tears.
just had all that to do on mine and the dis pack all spread over 3 days but it's good to have the feeling you have done it and done it well. :y :y
Proz
Re: Been Busy
« Reply #4 on: 06 March 2009, 17:35:52 »
Yeah it feels good not to have to line the pockets of the garage ..... i'll be doing timing belts soon at this rate  :D
Re: Been Busy
« Reply #5 on: 06 March 2009, 17:44:59 »
Well done Proz,4 pot timing belt is very easy,if you can do what you did today then it should be well within your capabilities. :y
Proz
Re: Been Busy
« Reply #6 on: 06 March 2009, 17:53:36 »
Its not due for 30 odd thousand yet cause it was done by Vx not long ago , but im sure with the help of the dvd from the shop id give it a go when it is due  :y
Re: Been Busy
« Reply #7 on: 06 March 2009, 18:23:35 »
4 pot cambelt is nice and easy.  Hopefully, by the time yours is next due, we should have an improved cambelt DVD :y
