Author Topic: vx astra .16. 8 valve  (Read 1273 times)
miggcddave
  •   south wales
« on: 23 March 2009, 09:46:22 »
price quote for 1 rocker arm head gasket all seals oil and filter replaced ive got a quote for (£ 170 all in is that a good price )
Re: vx astra .16. 8 valve
« Reply #1 on: 23 March 2009, 10:32:56 »
Sounds pretty reasonable to me... In fact, it sounds too cheap! Is this just labour or supply and fit?
But it begs the question as to why only one rocker arm :-/ :-/ :-/
miggcddave
  •   south wales
« Reply #2 on: 23 March 2009, 11:04:04 »
a mate of mine is doing work  :y and 1 rocker arm snapped in half all the rest are ok
« Reply #3 on: 23 March 2009, 11:06:48 »
Has it got a stuck valve?
Cant think of any other reason why the rocker would snap.
Check the guides carefuly once the head is removed!
miggcddave
  •   south wales
« Reply #4 on: 23 March 2009, 11:09:07 »
ok thanks mate :y
miggcddave
  •   south wales
« Reply #5 on: 23 March 2009, 11:59:09 »
just checked valve guide and valve all ok . rocker arm on no 4 cylinder exhuast valve badly worn through causing it to snap . cant see any other reason for it to snap all others ok  :-/
« Reply #6 on: 23 March 2009, 12:59:55 »
In which case the cam will be goosed to!
miggcddave
  •   south wales
« Reply #7 on: 23 March 2009, 13:10:45 »
cam looks ok slight marking on the lobes but nothing to worry about  :y all looks fine . i think we will refit head and keep a check on it  ;)
« Reply #8 on: 23 March 2009, 13:13:23 »
You do know that you can do the rocker without taking the head off.....
miggcddave
  •   south wales
« Reply #9 on: 23 March 2009, 13:48:46 »
yes i did know but wanted to check valve and guide . and did not have tool to decompress valves to take cam out . head just about to go back on now  :y fingers crossed all will be fine thanks for your info mark  :y
