Author Topic: leaking rear foot well  (Read 1663 times)
gewilkes
« on: 21 February 2009, 22:31:08 »
 :( Hi Ya.
Can anybody tell me about my rear passenger (Driver side) foot well it's starting to get very wet when it rains now , when it's parked up?
Thanks :y
Re: leaking rear foot well
« Reply #1 on: 21 February 2009, 22:36:39 »
door seal leaking?
iainb
  • West Midlands
« Reply #2 on: 21 February 2009, 22:47:48 »
Door card membrain removed ?
« Reply #3 on: 22 February 2009, 01:17:09 »
probably blocked drains on the bottom edge of the door, and/or the membrane has given way allowing water in through the door card.. This is common on BMWs. You may find the door card is wet at the bottom. Depends where the membrane has come away.There are two seals on the doors, be suprised if water got passed both tbh. Hth
« Last Edit: 22 February 2009, 01:20:39 by chrisgixer »
gewilkes
« Reply #4 on: 22 February 2009, 17:17:11 »
Hi to everybody that answered my question, will have a look when i get back from trip. In the sun should take car with me and dry it out in the Sun. 8-) :y
gewilkes
« Reply #5 on: 27 March 2009, 09:25:46 »
Well Back from trip and the foot well was full so had to sort it out so opened boot up and that was wet to? to cut a long story short it was the weld that welds the roof pillars to the back of the car around the boot area, were all the water sits when you open the boot with my car sitting on a hill it stays there.
So a bit of a clean up of the rust and found a hole so just filled it in hope this will stop the leak.
Thanks for the other help.
Gerry :y
« Reply #6 on: 27 March 2009, 11:34:26 »
Woo, thats a new one afaik, any pics?
Welung666
« Reply #7 on: 27 March 2009, 11:39:42 »
Is it coming down the C post? Could be a sunroof drain pipe come off at the top :y
vauxmad
  • Oswestry, Shropshire
« Reply #8 on: 27 March 2009, 12:51:25 »
probaly the door seal
« Reply #9 on: 27 March 2009, 13:28:34 »
If he's found a hole ... it was probably that ...  :)
Welung666
« Reply #10 on: 27 March 2009, 13:49:01 »
We'll have to see then :y
