Author Topic: Hd ready or Full Hd?  (Read 3369 times)
MadMark73
  • Taunton. Somerset.
  • She is a bit of an animal!!!
    • 98 3.0 Elite Estate
« on: 29 March 2009, 20:50:56 »
Hi all. Getting sky HD+ on saturday so need to get a new TV.
What is the difference between the two types and any suggestions on which telly.
Looking for a 37" and thats as far as we have got.
So any advice greatly received. Thanks in advance.
Re: Hd ready or Full Hd?
« Reply #1 on: 29 March 2009, 20:55:22 »
Full HD is exactly that....HD ready generaly means Not-HD but, as you can imagine, if they called it Not-Hd then they would not sell!
Be aware that Sky HD is 720P or 1080i at best and not full HD like say a blue ray player
« Last Edit: 29 March 2009, 21:00:54 by Mark »
« Reply #2 on: 29 March 2009, 21:11:24 »
HD means HD, HD-ready means non-HD. that about sums it up
« Reply #3 on: 29 March 2009, 21:14:16 »
So does that view OK on 1080p TV's?
« Reply #4 on: 29 March 2009, 21:15:15 »
As well as Sky HD shows anywhere :P
720p shows fine on a 1080p telly.
« Reply #5 on: 29 March 2009, 21:17:49 »
also some TVs only do 720 and are badged HD, you want 1080  :y
mathewst
  • Split, Croatia
    • v40
« Reply #6 on: 29 March 2009, 21:19:52 »
1080 is full HD Mark.
The markings for hd are 720 and 1080
1080 means full HD or if you prefer the resolution is 1920 vertical and 1080 horizontal lines.
720 means 720 horizontal lines
mathewst
  • Split, Croatia
    • v40
« Reply #7 on: 29 March 2009, 21:20:52 »
MadMark what kind of tv dou you want to buy?
Plasma or LCD?
« Reply #8 on: 29 March 2009, 21:25:23 »
you want LCD over Plasma, LCD is cheaper to run and will last longer
« Reply #9 on: 29 March 2009, 21:25:38 »
Nobody in there right mind buys a plasma any more
« Reply #10 on: 29 March 2009, 21:34:11 »
Plasma still has a place, but not in the home ;D
mathewst
  • Split, Croatia
    • v40
« Reply #11 on: 29 March 2009, 21:34:25 »
Actually both plasma and lcd have their advantages Mark.
Expected duration of the plasma screen is about 30 000 hours.
Itf its turned on 8 hrs[ch733][ch733] a day that's 10 years.
And the contrast is way better, and no dead pixels on it and black colour on plasma is actually black. And usually it's cheaper
LCD is lighter, consumes far less power, and can have higher resolution (this doesn't always mean better picture).
Probably people should compare by looking and then deciding what to buy
« Reply #12 on: 29 March 2009, 21:34:30 »
Correct....in the garage!  ;D ;D
« Reply #13 on: 29 March 2009, 21:38:24 »
Very wrong....its not the screens that have issues, its the drive electronics. The plasma pixel requires a pre-charge (to wake it up), a strike (to light it), a hold period and tehn a discharge (to turn it off).....its the electronics driving the panel that are the issue. I did a review on a new Matsushita drive chip a few years ago, the package was running at max dissipation which is clearly where the life limit comes from.
And you dont get tru black....unless its turned off because the phosphor has a glow time of approx 30 seconds!
Contrast is the same now....so thats not a plus by any means
And dead pixels are just as likley because the same technology is used for the interconnects!
« Reply #14 on: 29 March 2009, 21:39:24 »
One or 2 places where the glass front is more preferrable to the delicate lcd.  Other than that, can't see any advantage to plasma...
