Author Topic: Quick MOT question...  (Read 1275 times)
Ian_D
  • York
« on: 30 March 2009, 18:45:42 »
My old Vectra, which ive sold to my mate has just gone in for its MOT.
Its failed on 'Centre Rear brake pipe excessively corroded (3.6.B.2c)'
Thats all it failed on, but it doesn't say which side :-/ Does this mean both sides need replacing? or do I just assume its the one which looks the worst?  :o
I thought they should put which side of the car it is, eg 'N/S Rear brake pipe excessively corroded (3.6.B.2c)' etc?  :-?
[size=12]
Re: Quick MOT question...
« Reply #1 on: 30 March 2009, 18:49:49 »
Lol, moving to general chat (its a Vectra sorry)
But, there is a brake pipe that runs across the rear from drivers side to passenger side (the pipes go down the drivers side of the car) and is likely to be obvious
« Reply #2 on: 30 March 2009, 18:50:04 »
if its an older abs setup, it may only have one circuit to the back, thus 1 pipe?
Ian_D
  • York
« Reply #3 on: 30 March 2009, 19:09:39 »
Sorry about it been in the wrong section, My fault, I was rushing the post as my tea was ready!  ;D
Any, I'm off round to have a look at the car, and hopefully replace the pipe with a copper one.  :y Knowing my luck it will be the longest pipe on the car! >:(
TB, it is an oldish Vectra (1997) but im 80% sure theres 4 brake pipes from the ABS unit?  :-/
[size=12]
« Reply #4 on: 30 March 2009, 19:11:28 »
It might be, some had a join by the drivers rear wheel, some didn't.
You cna always fit a join as that is an acceptable repair method
Ian_D
  • York
« Reply #5 on: 30 March 2009, 19:15:30 »
Depends if my brake flaring tool will flare the steel pipes, They maybe a bit tough strong?  :-X Its only a cheap draper one!  :-[
[size=12]
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #6 on: 30 March 2009, 19:17:17 »
Brake pipes on the vectra is very common my old one had to have the whole rears replaced so count yourself lucky
Old/New V6's deffinatly have 2x rear pipes  :y
