Author Topic: New GM aux belt  (Read 622 times)
New GM aux belt
« on: 05 April 2009, 14:14:34 »
Eventually god around to popping on a new aux belt on the MV6, old one was a bit old and buggered, supposedly changed with cambelt at 92k (60k ago), but I doubt it!!
Anyway, new one, GM part number from dealer, but with Contitech written on the belt itself, bugger me it was a tight fit :o
I remember that some pattern ones where a shade shorter, wonder if GM are buying up some of these pattern ones....
ians
  • Reading
Re: New GM aux belt
« Reply #1 on: 06 April 2009, 10:52:17 »
I had one of those shorter ones (came from Autovaux - can't recall the make but wasn't branded Contitech).  Symptoms were a loud squeal for a minute or two after starting off from cold.   The adjuster was right over on the limit to get it on.
Autovaux replaced it without question.
Re: New GM aux belt
« Reply #2 on: 06 April 2009, 11:05:33 »
Not squeal, and tensioner has some left in it.
It was just a sod to get on, had to remove all the bagpipes in the end...
Re: New GM aux belt
« Reply #3 on: 06 April 2009, 11:07:10 »
Amateur...bet you were trying to get it on the tensioner or alternator pulley.
If there is some adjustement left then it will be fine.
Re: New GM aux belt
« Reply #4 on: 06 April 2009, 11:10:02 »
I always aim for the waterpump as that is always easier :y - just wasn't enough room to have tensionerfully untensioned, SIA pipes, and my mits to flip it on, hence bagpipe removal ;D  :-[
