Author Topic: crappy laptop  (Read 2504 times)
cam2502
  • dumfries,scotland
    • 08 BMW 520d & 03 Saab 95
crappy laptop
« on: 06 April 2009, 13:44:56 »
I have a hp pavilion ze4800 laptop that my mrs bought for me 3 years ago (£500). Instead of shelling out for a new one i want to know if i can add memory to it as its only a 256mb ram and i need at least 1gb. Is this possible and how much do you reckon that would cost me?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: crappy laptop
« Reply #1 on: 06 April 2009, 13:58:39 »
Not much, flip it over, undo the Ram Door and see whats what.
« Last Edit: 06 April 2009, 13:59:02 by zirk »
mathewst
  • Split, Croatia
    • v40
Re: crappy laptop
« Reply #2 on: 06 April 2009, 14:04:13 »
Not sure what memory actually goes in it.
I don't think that's a ddr2 (it's a bit old laptop so the old memory will cost a little more than for new ones).
And probably you cannot expand the memory beyond 1 or 2 Gb.
Why do you need at least 1 Gb??
Explain it a little and I'll probably be able to be a little bit more helpfull
hoj
  • BURY
Re: crappy laptop
« Reply #3 on: 06 April 2009, 14:07:12 »
Loads of different items on ebay try 200232539052  for memory
3.2 Elite in Oyster
omegadti
  • Glasgow
    • omega dti
Re: crappy laptop
« Reply #4 on: 06 April 2009, 14:16:50 »
Have a look at this link http://www.4allmemory.com/index.cfm?fuseaction=search.memorySearch&model_id=-5003
it tells you what memory you need - your computer will only take 1gb of memory so you might need to fit it in 2 512mb chips - try Spot-On computers in Manchester (mail order on the net - check them on Google) but shouldn't be much more than £10 per chip
mathewst
  • Split, Croatia
    • v40
Re: crappy laptop
« Reply #5 on: 06 April 2009, 14:21:39 »
Yep I checked it and your Laptop supports only old SDRAM.
Whatever you need the 1gb (Vista or something similar) it's just a waste of money because the CPU of the laptop is let's say barely ok but all the rest is fit for scrap if you plan to run anything that needs a fair bit of memory, hdd speed or vga usage
crappy laptop
« Reply #6 on: 06 April 2009, 14:48:33 »
[movedhere] Omega General Help [move by] TheBoy.
Re: crappy laptop
« Reply #7 on: 06 April 2009, 14:49:51 »
I'd recommend crucial for memory.
But at 3yrs old, its tired, and at the end of its life...
(says TheBoy who's Tech2 laptop is about to have its 9th Birthday, and no matter how he tries, it won't die)
eddie
  • Cardiff
Re: crappy laptop
« Reply #8 on: 06 April 2009, 14:58:49 »
Have a bit of fun and bung Linux on it!
Wife's DEll lappy (2yrs old) has just packed up-AC adapter goes out when plugged in. Output measured 35 volts whenI tested it-instead of 19.5!
When I contacted DEll's (cosmopolitan) Helpdesk I was assured that it needed a new 'Mainboard' at a cost of £185 +vat OR if I took out a new 2yr warranty for£150 they would knock 10%  of that price!  I think not >:(
eddie
Re: crappy laptop
« Reply #9 on: 06 April 2009, 15:26:39 »
eddie
Hasn't got the memory to run graphical Linux. So unless you are a command line junkie, stick to XP with that little RAM.
Ken T
  • Stockport
Re: crappy laptop
« Reply #10 on: 06 April 2009, 16:07:00 »
Older laptops tend to last a lot longer than new stuff. I have just sold an Advent 7015 (P4-2.80Ghz) for a reasonable amount, still working well. My son's DV9000 just back from HP after getting a replacement motherboard fitted (Nvidia problems ) has died with the same problem after 4 months  :'( :'( :'(
Ken
« Last Edit: 06 April 2009, 16:07:18 by Ken_T »
cam2502
  • dumfries,scotland
Re: crappy laptop
« Reply #11 on: 06 April 2009, 22:10:47 »
Thanks for your comments and advice guys. Think i'll bin it and get a new one! :-?
Re: crappy laptop
« Reply #12 on: 06 April 2009, 22:18:08 »
will take 1G, and cost approx £65, plus the cost of an antistatic strap (don't attempt without, you WILL shag the memory (though think you've probably got away with it for a few months)).
http://www.crucial.com/uk/store/listparts.aspx?model=Pavilion%20ze4800%20Series
Re: crappy laptop
« Reply #13 on: 06 April 2009, 22:18:40 »
obviously your choice if you think its worth it :)
cam2502
  • dumfries,scotland
Re: crappy laptop
« Reply #14 on: 06 April 2009, 22:20:53 »
Just a though.....much would i get for it on fleabay do you reckon?
