Author Topic: code reader and rest tool  (Read 1322 times)
petejjf
  • nuneaton
« on: 11 April 2009, 14:30:19 »
thinking of getting a fault code reader and reset tool..i have a x reg. 2000. omega ..do i need a obd2..or a eobd
anyone know... ta pete
Re: code reader and rest tool
« Reply #1 on: 11 April 2009, 14:33:32 »
No generic one will work, as non eobd/obdii compliant
froezen
  • Scarborough,UK
« Reply #2 on: 11 April 2009, 14:37:51 »
I read somewhere that the fault codes can be 'pushed off' the ECU by turning the ignition on (but not starting) and then off 20 times. Is this true? I cannot test this as I have no faults.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 11 April 2009, 14:48:59 »
Not sure about that one, Paper Clip test works on most.
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Last Edit: 11 April 2009, 14:51:39 by zirk »
froezen
  • Scarborough,UK
« Reply #4 on: 11 April 2009, 15:45:30 »
By 'pushed off', I meant cleared, not read. ;-)
  • Online Online
« Reply #5 on: 11 April 2009, 16:45:07 »
They say that 20 'clean starts' will clear the ECU of any fault codes. The miss-fire codes have cleared by themselves from SWMBO's Astra G
« Reply #6 on: 12 April 2009, 12:19:41 »
no - 20 'clean' starts (ie, it starts and runs for a while).
some codes clear straight away, some never appear to clear (eg immobiliser and eml ones), some clear after a while
