Author Topic: Had to do some welding today  (Read 1103 times)
waspy
« on: 13 April 2009, 21:28:49 »
I noticed my mid section of the exhaust had some pin holes & needed welding. So i set about it today, but when i got the car in the air & i was proding around, i stuck my finger through the exhaust ;D ;D. So i set about loosening the bracket (which came free easy :o ) Then after removing the back box i also found that needed welding too :'(
I've welded the back box up & that should last a while now :y
The mid section's still on the car, because the stud snapped on the flange to the Cat & the second one's gona do the same :'( >:( >:( but every things loosened off & ready for more welding tomorrow. The little stainless bracket just down from the turbo was right a pig, because some silly arse had used a mild steel 13mm nut instead of a stainless one. I had to use a nut splitter to remove it in the end >:(
The cat's gona be removed & a section of pipe welded in place. Diesel's don't need cats ;) & so this should make a difference on performance :y So i've been told by a diesel specialist (we'll see)
One thing that's puzzled me was upon removing the back box there was no difference in noise levels :-? :-? So i could drive around with no back box at all :D
Appologize for the lengthy post, only i've been alone all day & had no one to talk to ;D
Re: Had to do some welding today
« Reply #1 on: 13 April 2009, 21:32:51 »
I noticed on my old TD Cavalier that it was just as quiet with the back box removed!
dieseldean
  • chesterfield
« Reply #2 on: 13 April 2009, 21:33:55 »
2.5td the same ::)
waspy
« Reply #3 on: 13 April 2009, 21:34:34 »
It's very wierd :-/ :-/ :-/
Debs.
« Reply #4 on: 13 April 2009, 21:36:01 »
With that welding task you have become a "Miggy-MIG`er" ;D
waspy
« Reply #5 on: 13 April 2009, 21:43:27 »
 ;D ;D ;D
I've been a MIG'er for 20 years now (with a 6 year break), though i've only just bought my own welder ::) :-[
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
« Reply #6 on: 13 April 2009, 21:48:56 »
What happens come MOT time? I do know that my clit valver had had its cat removed but sailed through it MOT  :-/
« Reply #7 on: 13 April 2009, 23:35:37 »
The turbo doing its' job. Extracting energy from the exhaust gases. :y
Omegatoy
  • UK
« Reply #8 on: 14 April 2009, 08:06:14 »
yep Turbo is effectively a very good silencer as it extracts the energy form the gasses, mine hasnt had a rear box for 3 years now but does have twin pipes as many will know :y never had slightest problem on MOT test!! have driven it with tailgate open on first catch, and the noise when the turbo is on full chat is lovely!! on tickover  you wouldnt know anything was missing!! :y
« Reply #9 on: 14 April 2009, 08:33:28 »
Yep, turbo vanes are excellent at absorbing the energy of the exhaust gases (which is what they are supposed to do)
Welung666
« Reply #10 on: 14 April 2009, 09:59:04 »
Are the 2.2 petrol and diesel cat sections the same?
waspy
« Reply #11 on: 14 April 2009, 17:18:46 »
The cat section bolts onto a down pipe from the turbo via a flange & two bolts, i've never seen a petrol version so i'm  :-/ :-/
Though someone will know :y
