Pages: 1 [2] 3  All   Go Down
Author Topic: Another Aldi Offer  (Read 2373 times)
Re: Another Aldi Offer
« Reply #15 on: 16 April 2009, 14:12:23 »
check the inverter thread from a day or 2 ago, maplins have some on offer at the mo.
I got a nice 400w one for £29.99
« Reply #16 on: 16 April 2009, 14:13:14 »
Thanks Jimbob, will do! :y :y
« Reply #17 on: 16 April 2009, 14:18:21 »
Downside is im sure it would drain your battery very quickly if the engine wasnt on, which it doesnt tend to be when you are working on the car.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #18 on: 16 April 2009, 14:33:24 »
Had one since they were on offer last year, it doubles as a tent light when were at a meet.
Top tackle.
TuBy's new whipping boy.
« Reply #19 on: 16 April 2009, 14:37:43 »
If using one of these away from mains power it'd be better to get a 12v powered light in the first place. Plenty available from camping places, etc.
These are very efficient because, although they effectively contain their own inverter, it is only sized to provide the couple of watts the light needs so is much more efficient than a mains inverter designed for a couple of hundred watts, useful though they are.
« Reply #20 on: 16 April 2009, 14:40:58 »
Are you saying then that for someone in my situation it is best to have a small generator Jimbob? :-? :-?
« Reply #21 on: 16 April 2009, 14:48:29 »
depends on what you want.
The light I have for car work is like that one, but has 30 odd led's instead of a tube, and has a rechargable battery in it.
Also works off mains, or fag lighter.
Most camping shops sell em.
« Reply #22 on: 16 April 2009, 14:56:10 »
Thanks again Jimbob :y :y
« Reply #23 on: 16 April 2009, 15:07:44 »
Trouble is LED's do not make good work lights.....the Aldi one is a CF type so much better for working with.
The inverter wont nobble a battery very quicky, the light is 20W max and even with efficiency taken into account, thats no more than 2 amp drawn which given the Omega battery is 50AH+....gives 25 hours use (assuming its ok and fully charged)
« Reply #24 on: 16 April 2009, 15:13:44 »
Thanks Mark :-* :-* ;) ;)
Debs.
« Reply #25 on: 16 April 2009, 15:14:14 »
Indeed; but why?.......is it because the light is polarised?.......or too narrow a band?
My LED flashlights are rubbish; even just for peering down into an oil tank to check the level.....the old fashioned tungsten filament 'beam' flashlights seem much better for task lighting.  :-/
« Reply #26 on: 16 April 2009, 15:50:49 »
Its simple, the LED is not a white light source, it is actualy a narrow red, Green and Blue light source.
This makes it appear white (ala white on a TV/Monitor screen) and for this they are very good.
The problem is that the light spectrum for each colour is very narrow (being related to the Energy gap of the semiconductor compound from which it is produced) and so when the light reflects off a surface,  you get a lot of detail lost as all surfaces reflect different wavelengths of light in differing amounts.
The result is lost detail and tiring light to work under.
One of the LED solutions being considered to improve the spectrum of light output from LED's is to use a UV LED with a phosphor coat ala a CF bulb!
STMO123
« Reply #27 on: 16 April 2009, 15:59:05 »
I knew all of that ::)
Debs.
« Reply #28 on: 16 April 2009, 16:05:39 »
`Brilliant explanation Mark; thankyou. :y
« Reply #29 on: 16 April 2009, 16:42:12 »
 ;D ;D ;D and very enlightening :D :D :D ;)
Pages: 1 [2] 3  All   Go Up
