Author Topic: aftermarket alarm/immob  (Read 1241 times)
Bumbazor
  • Worksop
« on: 21 April 2009, 13:16:28 »
Does anyone have a Toad ai606?
What does 5 beeps on disarm (after alarm) mean?
Welung666
Re: aftermarket alarm/immob
« Reply #1 on: 21 April 2009, 13:25:16 »
It tells you where the activation was but for the life of me I can't find the booklet for it! I'm fairly sure 3 beeps is the door pins.
Bumbazor
  • Worksop
« Reply #2 on: 21 April 2009, 13:28:56 »
Yeah I thought it was the circuit that activated but I have lost my booklet too!
I think 4 beeps is ultrasonics, so if you are right and I am right it's going to be the bonnet or boot pins. Must find that booklet though....
jjleonard
  • stevenage
« Reply #3 on: 21 April 2009, 13:33:15 »
I googled ai606 5 beeps -
this link http://www.clubgti.com/forum/showthread.php?t=95748
has two links to the manuals about 12 posts down.
HTH :y
Welung666
« Reply #4 on: 21 April 2009, 13:46:35 »
Thanks JJ, so you need to read the flashes on the LED when you disarm
Flashes
2      Sensor Optional sensors
3       Doors (-)
4      Boot/bonnet
5      Doors (+)
6      Ultrasonic sensors
7      Ignition
Bumbazor
  • Worksop
« Reply #5 on: 21 April 2009, 13:46:49 »
I found that too but it doesn't have the user guide booklet although it does have led flash codes (which I missed and can not recall) which look like they are different than the beep codes.
Welung666
« Reply #6 on: 21 April 2009, 13:48:59 »
No the single beep followed by 4 more beeps signals that an activation has happened, the LED flashes out the location of the activation :y
[edit]I used to fit 3 or 4 of these a week going back a good few years ago :y[/edit]
« Last Edit: 21 April 2009, 13:49:38 by Welung666 »
Bumbazor
  • Worksop
« Reply #7 on: 21 April 2009, 14:08:32 »
So I need to go back to the history of activations... just as well I can remember PIN!
Welung666
« Reply #8 on: 21 April 2009, 14:11:03 »
It is, just a shame putting it in is such a pain in the @rse ;D
Bumbazor
  • Worksop
« Reply #9 on: 21 April 2009, 14:15:40 »
Didn't need PIN in end but determined it's the boot or bonnet circuit.
Just one more thing; I assume it's the green flashes I count. I got some red in there too; slightly confusing.
Welung666
« Reply #10 on: 21 April 2009, 14:27:20 »
I think so, the manual doesn't say :y
Bumbazor
  • Worksop
« Reply #11 on: 21 April 2009, 14:34:37 »
I reckon so too.
I of course know where the bonnet switch is and can check that easily but I can't find the boot switch, or rather, where can I check that is a common place the boot circuit can fail?
Bumbazor
  • Worksop
« Reply #12 on: 22 April 2009, 12:34:47 »
Got it again today.
Could it be the heat as it's quite warm out there? Maybe it's causing some contacts to make/break when they swell and warp in the heat.
