Author Topic: TC on ex police Omega 3.0 MV6  (Read 1231 times)
graham-mv6
  • Lisburn N.I
« on: 27 April 2009, 17:03:24 »
I recently bought a ex police omega with a lsd there was no traction control button to turn it off, and when the fuse is taken out the speedo doesnt work.  I then fitted tc button but iam still unable to turn it off help please its running my fun :'(
nick v6
  • walsall / west midlands
Re: TC on ex police Omega 3.0 MV6
« Reply #1 on: 27 April 2009, 17:06:36 »
might do better posting that in the help section
or it may get moved by admin :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #2 on: 27 April 2009, 17:08:40 »
I think if the car has LSD it wont have the TC.... maybe wrong :-?
« Reply #3 on: 27 April 2009, 17:08:44 »
With ex-plod butchered wiring, you need to find the wire. It will likely be behind the radio/switch area somewhere, else you need to run a new wire to ecu.
« Reply #4 on: 27 April 2009, 17:09:27 »
I would guess it isnt fitted with TC. ;)
« Reply #5 on: 27 April 2009, 17:09:38 »
The ABS and Engine ECU has the capability, and it can't be disabled as a feature, so it should be do-able
« Reply #6 on: 27 April 2009, 17:11:26 »
wouldnt the TC sort of cancel out the effect of the LSD though? :-/
« Reply #7 on: 27 April 2009, 17:16:00 »
No.  They compliment each other to reduce wheelspin.
If you want LSD for drifting, thats different.
graham-mv6
  • Lisburn N.I
« Reply #8 on: 27 April 2009, 17:16:53 »
yh lsd near useless with traction control on :(
have seen some wires round near the headunit that have tape over them could be a possibility  ;)
« Reply #9 on: 27 April 2009, 17:19:42 »
Not for going faster round corners its not.  Fastest way around any corner on tarmac is with the back following the front ;)
For RWD fun, thats different
« Reply #10 on: 27 April 2009, 17:21:37 »
Just trying to imagine the combined effect.If one wheel is losing grip the LSD transfers power to the other one,if the TC is reducing power to that one at the same time because it senses wheelspin.......sounds a bit messy?
graham-mv6
  • Lisburn N.I
« Reply #11 on: 27 April 2009, 17:30:45 »
just want it off for some fun, was to used to my old 3.2 mv6 at the touch off button, instead of pulling fuse out, wouldnt want it permanently off to scary on back roads in the wet lol
« Reply #12 on: 27 April 2009, 18:17:20 »
Post 1998 ABS/TC will try to apply the brake to the spinning wheel (only), so similar intention as LSD, hence why they work well together (to stop wheel spin, again, I'm not talking about the fun element here)
