Author Topic: Work on Elite has begun (Smoothomega LOOK AWAY!!)  (Read 2101 times)
« on: 27 April 2009, 14:56:16 »
Warning to SmoothOmega. The following thread contains pictures of your pride and joy having the guts ripped out of it. Read on at your own risk  ;D
Anyhow - I picked up the Elite on Saturday
Firstly, thanks to Smoothomega for selling me such an honest and well described car :y
First job was to pop to a tyre centre and get a couple of new fronts. The existing ones were, as described, near the end of life. They were worn on both inner and outer edges and starting to wobble a tad - so sorted that on the way home.
Had a good laugh at the muppets in ETB, who couldn't get the wheels off - and quitely told one of the lads there he really shouldn't be lying under the car kicking the wheel off, while it's only on a jack  :-?
Anyhow, new tyres cured the noise and slight wobble, and handling was much much better.
I then took the beastie home - and decided to fit the new wishbones while there was still a few hours of light and sunshine. I started on the drivers one - what a barsteward. I had to beat ten bells out of the balljoint, and it was just generally quite fiddly - but I got it done. I only managed to to get the one side done, as I was working a shift later on in the evening.
Next day - I did the NS wishbone. Again, quite fiddly and hard to come apart etc, but got the job done.
So, with the wishbones done, it was time to start on my favourite job - the engine  :D
Bearing in mind this car has been mostly dealer serviced - check out the coolant condition below:
A few bits taken off the engine:  ::)
Note - the cams will be put in the bin - pending arrival of some 3.0 ones  8-)
And again - look at the colour inside the block and cooling system:
Cylinder heads - ready for re-furbing and porting.
One of the old head gaskets:
Next job, is to remove the oil cooler, fully refurb the heads, and do a LOT of cleaning before I Can start re-assembly...
The multirams were not working, so will have to check the vaccs etc, once it's back together...
« Last Edit: 27 April 2009, 14:57:13 by JamesV6CDX »
Re: Work on Elite has begun (Smoothomega LOOK AWAY!!)
« Reply #1 on: 27 April 2009, 15:05:05 »
Before you port the heads, get a 3.0 lower inlet  :y
« Reply #2 on: 27 April 2009, 15:05:41 »
Thanks mate - Mutantcav is sending me one, along with the G/A cams  :y
Martin_1962
« Reply #3 on: 27 April 2009, 15:16:14 »
Want to see a ported 2.6 head?
I have a partly done one in the shed.
« Reply #4 on: 27 April 2009, 15:16:53 »
yes please! May get you to give me a hand porting mine :y
« Reply #5 on: 27 April 2009, 15:23:29 »
Before
After
« Last Edit: 27 April 2009, 15:24:42 by Mark »
« Reply #6 on: 27 April 2009, 15:27:18 »
Before
After
And the difference is?  :-/
« Reply #7 on: 27 April 2009, 15:45:00 »
Before
After
The step from the plastic to ali...
« Reply #8 on: 27 April 2009, 15:45:47 »
Is that the black palstic bit? Is 3.0l one larger (inlet holes) then?
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #9 on: 27 April 2009, 16:06:41 »
Yes :y
Omega man 2
« Reply #10 on: 27 April 2009, 16:08:20 »
Yes :y
What differance would it make to a 2.5? ::) ::)
Martin_1962
« Reply #11 on: 27 April 2009, 16:15:27 »
Smoother flow, the step will create a lot of turbulence which will slow down more than the step without flowing.
You always want a smooth path (not shiney - look at golf balls) with no steps and no intrusions.
nick v6
  • walsall / west midlands
« Reply #12 on: 27 April 2009, 16:19:45 »
if you have ever watched berny and lepu in chop shop
the first thing berny does is take that step off the ports :y
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #13 on: 27 April 2009, 16:44:50 »
What are you using, a dremel?
« Last Edit: 27 April 2009, 16:49:49 by alexandjen »
Trade club card holder
Code scanner available
Martin_1962
« Reply #14 on: 27 April 2009, 16:53:31 »
Big round file to get the corners out & tidy with B&D Wizard
