Pages: 1 [2] 3 4 5 6   Go Down
Author Topic: IT help - MAC address Invalid  (Read 8798 times)
Re: IT help - MAC address Invalid
« Reply #15 on: 07 April 2009, 22:49:16 »
I need to know what ram you have cos you obviously didn't have this much ram when you ran previous operating system. Are they pairs, what make are they and what are the individual specs of the modules.
the ram is fine - he just tried to massively overclock it, with the expected result!
no i didn't it's ddr800 ie 400mhz running twice per cycle to give 800mhz, the bios setting was auto and i changed it to ddr800 not ddr1066
ddr800? Don't you mean ddr2-800? if so, quad pumped off a 200Mhz clock
« Reply #16 on: 07 April 2009, 22:53:00 »
Before the purist come out stating the inaccuracy above, its actually dual pumped, but ran at double speed internally, so same effect as quad pumped. But technically not the same. If that makes sense?
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #17 on: 07 April 2009, 22:55:41 »
that's why you do pc's and i draw houses :-[
so is this right then :
Number of processors 1
Number of cores 4 per processor
Number of threads 4 per processor
Name AMD Phenom X4 9950 Black Edition
Code Name Agena
Specification AMD Phenom(tm) 9950 Quad-Core Processor
Package Socket AM2+ (940)
Family/Model/Stepping F.2.3
Extended Family/Model 10.2
Brand ID 11
Core Stepping DR-B3
Technology 65 nm
Core Speed 2600.0 MHz
Multiplier x Bus speed 13.0 x 200.0 MHz
HT Link speed 2000.0 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
L1 Data cache (per processor) 4 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache (per processor) 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache (per processor) 4 x 512 KBytes, 16-way set associative, 64-byte line size
L3 cache (per processor) 2 MBytes, 32-way set associative, 64-byte line size
Chipset & Memory
Northbridge NVIDIA GeForce 8200 rev. A2
Southbridge NVIDIA ID075C rev. A2
Memory Type DDR2
Memory Size 8192 MBytes
Memory Frequency 200.0 MHz (1:1)
CAS# Latency (tCL) 6.0 clocks
RAS# to CAS# (tRCD) 3 clocks
RAS# Precharge (tRP) 3 clocks
Cycle Time (tRAS) 9 clocks
Bank Cycle Time (tRC) 12 clocks
Command Rate (CR) 2T
System
System Manufacturer To Be Filled By O.E.M.
System Name To Be Filled By O.E.M.
System S/N To Be Filled By O.E.M.
Mainboard Vendor ASRock
Mainboard Model K10N78
BIOS Vendor American Megatrends Inc.
BIOS Version P1.30
BIOS Date 02/05/2009
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 2048 MBytes, unknown brand
Module 2 DDR2, PC2-6400 (400 MHz), 2048 MBytes, unknown brand
Module 3 DDR2, PC2-6400 (400 MHz), 2048 MBytes, unknown brand
Module 4 DDR2, PC2-6400 (400 MHz), 2048 MBytes, unknown brand
Software
Windows Version Microsoft Windows Vista (6.0) Ultimate Edition Service Pack 1 (Build 6001)
DirectX Version 10.0
« Reply #18 on: 07 April 2009, 22:55:49 »
I still haven't explained myself that well - sorry, its the Leffe ::)
DDR2-800 has a 200Mhz clock. That is correct.
GG
  • Milton Keynes
  • If kicking doesn't work, then hit it with a hammer
« Reply #19 on: 07 April 2009, 22:57:07 »
Maybe still able to help then I have lots of experience with ASRock from previous poorer days, not that I'm rich now  :y
« Reply #20 on: 07 April 2009, 22:58:05 »
Code Name Agena
Brand ID 11
Core Stepping DR-B3
Technology 65 nm
Chipset & Memory
Memory Type DDR2
System
BIOS Version P1.30
Memory SPD
Software
That looks right depending on what clock its using for memory - due to internal and external sync clocks running at double/half the speed of each other.
BTW, hooky copies of Vista will come to bite you on the arse - buy it if you want to use it. Ultimate is generally not the best version costwise, unless you need to be in an AD and have media center.
HerefordElite
  • Hereford
« Reply #21 on: 07 April 2009, 23:01:18 »
well i'm poor hence the cheap mb system so any advice greatly appreciated becasue i've spent a week tryin to sort this >:(
GG
  • Milton Keynes
« Reply #22 on: 07 April 2009, 23:11:08 »
Try this then. the boy won't like it probably  :-X :-X
You need to download this utility from
http://www.ami.com/support/downloadagreement.cfm?DLFile=support/downloads/amiflash.zip&InpDrvID=90.
And then go to DOS mode, n type command like,
D:\...........\afudos /mxxxxxxxxxxxx
There is /m is the command number 12 times x is your mac ID.
You can find your MAC somewhere on your Motherboard
MindlessJD
  • Locks Heath, Hampshire
  • Mac Maniac
« Reply #23 on: 07 April 2009, 23:16:55 »
You wouldn't have these problems with a Mac!  ;)
General House Repairs in South Hampshire
-- http://www.lfdennett.co.uk --
HerefordElite
  • Hereford
« Reply #24 on: 07 April 2009, 23:17:43 »
i've found several numbers all over the board but not sure if MAC addy i know it has 12 digits but none quite look right :-/
93M0X1055011
093R021-00424
80-MXG 9N0-A1A03   W11
001966BA9121
sorry for sounding useless but i am
HerefordElite
  • Hereford
« Reply #25 on: 07 April 2009, 23:18:10 »
I'll do the jokes thanks :D
MindlessJD
  • Mac Maniac
« Reply #26 on: 07 April 2009, 23:20:18 »
Who was joking?
HerefordElite
  • Hereford
« Reply #27 on: 08 April 2009, 00:10:24 »
93M0X1055011
093R021-00424
001966BA9121
used the afuwin prog to flash new mac to bios (001966BA9121 was the only one that it would let me enter)
doesn't seem to have worked :-/
GG
  • Milton Keynes
« Reply #28 on: 08 April 2009, 00:15:11 »
93M0X1055011
093R021-00424
001966BA9121
go into windows
find command prompt
type
ipconfig/all {press enter}
the physical address is your ip
Be back on line tomorrow if you still lost  :y
HerefordElite
  • Hereford
« Reply #29 on: 08 April 2009, 00:33:45 »
Windows IP Configuration
   Host Name . . . . . . . . . . . . : Home-PC
   Primary Dns Suffix  . . . . . . . :
   Node Type . . . . . . . . . . . . : Hybrid
   IP Routing Enabled. . . . . . . . : No
   WINS Proxy Enabled. . . . . . . . : No
   DNS Suffix Search List. . . . . . : home
Wireless LAN adapter Wireless Network Connection:
   Connection-specific DNS Suffix  . : home
   Description . . . . . . . . . . . : NETGEAR WG311v3 54Mbps Wireless PCI Adapter
   Physical Address. . . . . . . . . : 00-14-6C-C4-B0-69
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::add6:2e07:ee19:4e62%16(Preferred)
   IPv4 Address. . . . . . . . . . . : 192.168.1.67(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.255.0
   Lease Obtained. . . . . . . . . . : 08 April 2009 00:32:00
   Lease Expires . . . . . . . . . . : 09 April 2009 00:32:00
   Default Gateway . . . . . . . . . : 192.168.1.254
   DHCP Server . . . . . . . . . . . : 192.168.1.254
   DNS Servers . . . . . . . . . . . : 192.168.1.254
   NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 6:
   Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
   Physical Address. . . . . . . . . : 02-00-54-55-4E-01
   DHCP Enabled. . . . . . . . . . . : No
   IPv6 Address. . . . . . . . . . . : 2001:0:d5c7:a2d6:4fd:3d80:3f57:febc(Preferred)
   Link-local IPv6 Address . . . . . : fe80::4fd:3d80:3f57:febc%11(Preferred)
   Default Gateway . . . . . . . . . : ::
   NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 7:
   Media State . . . . . . . . . . . : Media disconnected
   Description . . . . . . . . . . . : Microsoft ISATAP Adapter
   Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
Pages: 1 [2] 3 4 5 6   Go Up
