Author Topic: eBay problem - item not as described...  (Read 1371 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« on: 28 April 2009, 14:05:38 »
I bought some new rear shocks for the CG the other week, they were delivered today...  However they are not the same as the ones in the picture!
This is the advert and the shocks I bought for the CG...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=200319998142
Notice, at the right of the picture, you can see they are height adjustable, as are the ones on my CG (Brazil Model) which is a 52 registered bike.
The ones which arrived are these...
Nice and shiny, I'll give them that... However....
They are not height adjustable as in the pictures :S
Quick google look, the China model of the CG does not have adjustable suspension, but the Brazil model does!!  Now I did ask the seller prior to buying these IF they are compatible with the Brazil model, which they replied Yes
I asked:
They replied
So yeah... they aren't the ones as described in the picture (and yes, I did check my existing suspension against the picture in the listing, and they are the same exactly), the new ones are completely different.  I've not even offered them upto the bike to see if they fit either, as I'm not sure where to go with this...
Any advice??
Cheers  :(
Humbugs...
Bumbazor
  • Worksop
Re: eBay problem - item not as described...
« Reply #1 on: 28 April 2009, 14:08:57 »
Being compatible and like for like are different.
Sure, they might be compatible in that they fit (although not adjustable) but they're not a like for like replacement.
I think that's one area the seller might cause issue with, so have a better argument to throw back at them.
notacarbuff
  • Manchester
    • 3.0l Elite
« Reply #2 on: 28 April 2009, 14:17:02 »
They are not the items that you bid on so why should you go through the effort of making do. I would send them bad and get a refund, then spend your cash on the correct shocks.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #3 on: 28 April 2009, 14:26:07 »
Send them back mate, but your probaly going to have to swallow the return postage.
« Reply #4 on: 28 April 2009, 14:30:24 »
I would get intouch and ask if they have the adjustable ones as per the ebay picture
Deva1992
  • Portiere
« Reply #5 on: 28 April 2009, 14:37:29 »
Sounds like they are in the wrong to me
Deva1992, all round good egg and a bloody nice bloke to boot.....according to his Mum
« Reply #6 on: 28 April 2009, 14:47:38 »
So the height adjustment is that crude rotating collar at the base of the spring which sits aginst the roughly welded lump of metal?
It could be a simple mistake where they have picked the wrong ones up off the shelf.
Debs.
« Reply #7 on: 28 April 2009, 15:08:49 »
Clearly not what advertised or even slightly-close to the picture in the listing that the seller 'cautions you' to check against your originals.
My 2d. worth:
Give them a chance to put it right for you by contacting them asking them to supply the item you actually bid-upon.......if the seller is not willing or able to do so; then politely request a full refund (including your return postage costs): it was their mistake after all!
Leave any formal eBay/paypal complaint until the seller has had at least a chance to put it right.
miggcddave
  •   south wales
« Reply #8 on: 28 April 2009, 15:18:43 »
have you read this guys feedback  :( not the best ebayer ive seen  :o :o
platty
  • Cambridge
    • BMW 530d Sport
« Reply #9 on: 28 April 2009, 15:35:53 »
Please check image against your existing one or ask the question through eBay
Therefore you should receive what is shown in the picture IMO. As Debs quite rightly says, contact the seller first, then if non-cooperative you can go through the necessary channels.
Good luck  :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #10 on: 28 April 2009, 16:08:43 »
yeah tell him whats happened if hes a bad apple then use the paypal process!
dont forget the seller cant leave you neg FB but you can leave him neg FB after 2 weeks have passed :y
PaulW
« Reply #11 on: 28 April 2009, 17:47:52 »
Cheers guys! I've just sent this message to the seller, just trying to be polite really!  Checking first to see if they have sent the wrong item by mistake first, if no joy, I'll go down the other routes.
Hi
I received the shocks from you today thanks, however there is a small problem.  The ones I received don't appear to be the ones as pictured in your advert.
As you said about checking the ones on the bike against the ones in the picture for compatibility (which I did), the ones which arrived are completely different to the picture:
http://i130.photobucket.com/albums/p266/PaulW21781/Biking/My%20Bikes/CG125/38d000b1.jpg
As you can see they don't have the height adjustment screw.  I'm just wondering if the wrong ones have been sent by mistake?
Thanks
Paul
Also, I did take a screenshot of the advert page so you can see..  I've also printed off all the pages I've got screenshots off too.
See where it goes now I guess...
Humbugs...
« Reply #12 on: 28 April 2009, 18:53:44 »
A lot of bikes are to be fair to the CG125...
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #13 on: 28 April 2009, 19:05:28 »
The rotating collar is Pre-Load adjustment, not height.  :y
« Reply #14 on: 28 April 2009, 19:09:42 »
Actually, thats a good point, well presented, most bikes its the pre load, not height you adjust
