Author Topic: Silicon sealer  (Read 1093 times)
Tony H
  • liverpool
  • Black Elites are luurvley
Silicon sealer
« on: 29 April 2009, 21:29:32 »
Can anyone tell me what the difference is between ordinary silicon sealer and high modulous?  :-/
HolyCount
Re: Silicon sealer
« Reply #1 on: 29 April 2009, 21:41:46 »
spelt differently  ::)
Or ..... High modulous for the highest elongation and low modulous for the lowest elongation. High equals longer chains of polymer for more stretch the low modulous has short chains for less stretch. (as nicked from another forum !!)
« Last Edit: 29 April 2009, 21:45:09 by HolyCount »
Re: Silicon sealer
« Reply #2 on: 29 April 2009, 21:50:30 »
It describes the amount of movement required to break the joint....and its the opposite of what you would think.
i.e. high modulous is more rigid.....so if you want a flexible joint for say the edge of a bath then a low modulous silicon is required as it stretches more. A high modulous one would be used for calking brick joints and the like
The best I have found for bathrooms etc is the ice white stuff from Unibond
« Last Edit: 29 April 2009, 21:51:31 by Mark »
HolyCount
Re: Silicon sealer
« Reply #3 on: 29 April 2009, 21:55:41 »
Seems we have a variance of meaning here -- however, I bow to Marks DTM Calib's far superior knowledge on this one ( seeeing as I nicked my definition from someone else !!! )
Re: Silicon sealer
« Reply #4 on: 29 April 2009, 21:57:33 »
I should add that a natural cure silicon will also bond better
Tony H
  • liverpool
Re: Silicon sealer
« Reply #5 on: 29 April 2009, 21:57:58 »
Thanks Mark  :y
Re: Silicon sealer
« Reply #6 on: 29 April 2009, 21:59:03 »
So whats the application?
Tony H
  • liverpool
Re: Silicon sealer
« Reply #7 on: 29 April 2009, 23:00:10 »
Seals for a lugworm bait pump.
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Silicon sealer
« Reply #8 on: 30 April 2009, 01:09:22 »
V6 petrol or straight six diesel ?  :D
Tony H
  • liverpool
Re: Silicon sealer
« Reply #9 on: 30 April 2009, 21:00:26 »
One man power fitted with twin arms [smiley=2vrolijk_08.gif]
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
Re: Silicon sealer
« Reply #10 on: 30 April 2009, 23:49:22 »
Ah, serious piece of kit then  :y
