Author Topic: tyres  (Read 1747 times)
rikki_essex
  • essex
    • 2L gls estate with lpg 20
tyres
« on: 01 May 2009, 13:32:12 »
Just phoned the local garage up and ask for two  225/55/16 for the rear. the bloke turned round and said ive got two nearly new michelin 225/65/16 he said it would not be a problem. is that right??
regards Rik
Martin_1962
Re: tyres
« Reply #1 on: 01 May 2009, 13:37:44 »
You want 55 not 65 - might foul the wheel arches with 65
damon80
  • Wigan
Re: tyres
« Reply #2 on: 01 May 2009, 13:59:59 »
I agree - I've got 225/55/16's on mine, and there's next to no clearance from the top of the tyre and the bottom of the spring on the front strut...
rikki_essex
  • essex
Re: tyres
« Reply #3 on: 01 May 2009, 14:07:32 »
on mine there is quite a bit of room all round tho
regards Rik
Re: tyres
« Reply #4 on: 01 May 2009, 14:10:21 »
TBH I'd just have new ones... I don't like 2nd hand tyres unless I know their history ::) ::)
Re: tyres
« Reply #5 on: 01 May 2009, 14:10:31 »
A few issues
1) There Michelins...
2) There not original fit so insurnace issues
3) There second hand....so not worth more than 40 quid each fitted.
tyreburner
  • bedlington - northumberland
  • It werent a mig but boy was it fast!!!!! R.I.P
Re: tyres
« Reply #6 on: 01 May 2009, 14:11:39 »
Also it will possibly screw your speedo ( i dont know which wheels drive the speedo on a mig)
Also on my rover turbo i put slightly smaller front tyres on just so i could transport 2 wheels to leicster( long story) and it screwed my abs all the way there.
heres a link to a calculator of tyre sizes http://www.tyresave.co.uk/tyresiz2.html
Hope this helps
Mick
"well at least I'm lucky I don't have all the power in the world so I can't opps everything else up."
damon80
  • Wigan
Re: tyres
« Reply #7 on: 01 May 2009, 14:12:05 »
I'd stick to a tyre that gives you the proper rolling radius if I were you, for a couple of points...
- May affect your handing (different size tyres on different axles
- May knock your speedo accuracy out if the bigger tyres to to be fitted to the rear wheels
- Could foul the arches/suspension components with any kind of a load in your Miggy.
Too many question-marks if you ask me, but that's just my opinion...
EDIT: - must type quicker!!  ;D
« Last Edit: 01 May 2009, 14:13:09 by damon80 »
STMO123
Re: tyres
« Reply #8 on: 01 May 2009, 14:16:05 »
So you put new tyres on when you buy a used car? ::)
Re: tyres
« Reply #9 on: 01 May 2009, 14:17:34 »
Lol, I think the point is that second hand tyres are second hand for a reason....
STMO123
Re: tyres
« Reply #10 on: 01 May 2009, 14:18:26 »
Hope this helps
Mick
And here's one that will tell you how it affects your speedo reading:
http://www.miata.net/garage/tirecalc.html
rikki_essex
  • essex
Re: tyres
« Reply #11 on: 01 May 2009, 14:27:10 »
i got some off him before and they are still on the motor now. and he only whats £20 each for them
regards Rik
damon80
  • Wigan
Re: tyres
« Reply #12 on: 01 May 2009, 14:46:57 »
I'd phone around a couple more tyre places if I were you, and find one that has the exact size tyre you need - not worth taking the gamble  :y
Dusty
  • Shropshire
  • Erotic Romance Author
Re: tyres
« Reply #13 on: 01 May 2009, 18:48:06 »
I have just purchased four wanli 225/55 x16 tyres for my miggy.
£200 including fitting.I have found them excellent.
No need to buy part worn tyres in my view. :-* :-* :-*
Re: tyres
« Reply #14 on: 01 May 2009, 19:44:35 »
There are many issues with using incorrect size as stated above in detail..
As for the second hand tires: They must have minimum 5 mm average tread depth which will let you 2 mm of useable life.. And must have production dates not more than 4 years (even 4 years is too old imho)
