Author Topic: GM 2.2 Diesel coolant leak from bottom pulley area  (Read 953 times)
KDXKiller
« on: 04 May 2009, 17:44:01 »
Defecting Saab owner here, apologies..
Saab 9-3 with the same 2.2 diesel as fitted to the late model omega's.
It has suddenly devleoped a serious coolant leak from the vicinity of the bottom pulley, its dry above and i'm stumped.
My thoughts where that the only coolant in this area is internally in the water jackets in the block - hence my theory of a cracked block.
Given you chaps are more knowledgeable in this motor than the saab types appear to be - help or ideas would be appreciated, as a motor change is looking likely  >:( unfortunatley..
cheers in advance :y
miggy
Re: GM 2.2 Diesel coolant leak from bottom pulley area
« Reply #1 on: 04 May 2009, 17:45:11 »
Theres an echo
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #2 on: 04 May 2009, 17:46:41 »
WtF
           Needs new Keyboard maybe :-/
KDXKiller
« Reply #3 on: 04 May 2009, 18:03:32 »
took me several attempts to get it to post - didnt realise it had posted it twice - I've now deleted the the first post..
Apologies, anyway...
Fully functional keyboard in hand, back to the point lease ladies - enginey thing.. leaking, ideas?
hotel21
  • The Kingdom of Fife
« Reply #4 on: 04 May 2009, 18:06:56 »
There were 5 or 6 duplicates, now deleted, leaving one for replies.  Hopefully someone will assist.   :)
KDXKiller
« Reply #5 on: 04 May 2009, 18:41:34 »
any takers for a spot of advice on water pump changing?
willyboy
  • Leeds. West Yorks
  • Can Do !!
« Reply #6 on: 04 May 2009, 19:59:48 »
No doubt someone with more info on the diesel will be along shortly, only messed with petrol engines  :-[
