Author Topic: Elite Progress  (Read 1905 times)
Elite Progress
« on: 03 May 2009, 23:06:30 »
Old oil cooler removed, block totally cleaned, and brand new oil cooler kit fitted and sealed.
Heads re-furbed and head work complete
Knackered exhaust manifold thread sorted in one hole
Manifolds fitted, with Elring multi layer steel gaskets
Heads re-fitted to car
Drivers side fully torqued down - passenger currently on stage one
Rear coolant pipe fitted
Few other odds and sods.
Starting to look like an engine now - tomorrow involves:
Followers and camshafts (3.0) fitted - and cam sprockets
Coolant bridge
Cambelt kit
Cam covers
Plugs, leads, etx...
Blah....   should hopefully have it running tomorrow evening all being well  :y
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Re: Elite Progress
« Reply #1 on: 03 May 2009, 23:13:22 »
Sounds as if is going well :y :y
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
Re: Elite Progress
« Reply #2 on: 03 May 2009, 23:41:37 »
I do miss her James  :'( Give me first dibs if you sell her again  :y
Re: Elite Progress
« Reply #3 on: 03 May 2009, 23:51:07 »
Aye - you'll want her even more with a totally refurbed top end and an extra 20bhp... ;D
By the way, if you thought it was quick before - the multirams were not working - it will absolutely fly when they are operational too ;D :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Elite Progress
« Reply #4 on: 04 May 2009, 00:45:00 »
james would doing this porting to a 3.0 give it an extra 20bhp? also dont suppose you know if the 3.0s inlet divider can be ported like the 2.5s?
Re: Elite Progress
« Reply #5 on: 04 May 2009, 21:35:21 »
Hiya Tom - only expecting a couple of BHP from porting - the main increase comes from fitting 3.0 cams :y
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Elite Progress
« Reply #6 on: 04 May 2009, 21:36:40 »
not worth doing to a 3litre then?
Re: Elite Progress
« Reply #7 on: 04 May 2009, 21:42:19 »
May be worth putting some 3.2 manifolds on it - that could be interesting!
Re: Elite Progress
« Reply #8 on: 04 May 2009, 21:47:56 »
So you have used the 2.6 gasket for the 2.5 then?
Not sure I would be to comfortable with that given the 1.6mm larger bore on the 2.6
Re: Elite Progress
« Reply #9 on: 04 May 2009, 21:50:19 »
Would that not leave a very small gap between the block and the heads?  :-/
The fire rings would not meet the cylinders? They would be slightly inset  :-/
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Elite Progress
« Reply #10 on: 04 May 2009, 21:53:31 »
3.2 Inlets eh hmmmm ill keep my eye out for a 3.2 been broken up now thanks
Re: Elite Progress
« Reply #11 on: 04 May 2009, 21:54:31 »
Yep you would get a small indent around the tops of the bores.
Might be ok but could also create a hot spot and cause issues. It might also result in mega stresses as when the fuel exhaust mix lights, any in this recess would try to force the head and block apart.
Will be interesting to see the results!  :y
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: Elite Progress
« Reply #12 on: 04 May 2009, 21:54:57 »
what did you ues to do the porting? im considering doing a complete rebuild to and bottom
Re: Elite Progress
« Reply #13 on: 04 May 2009, 21:55:16 »
Pretty sure that the 3.2 and 3.0 inlets are the same, the 3.2 exhaust manifolds are better though
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Elite Progress
« Reply #14 on: 04 May 2009, 22:00:52 »
Is it simple to change the V6s manifolds the haynes book put me right off it started mentioning about removing the engine for the left bank is this nonsense? i could get hold of 3.2 manifolds very easily there is some in a scrapper engineless but with manifolds / precats in the boot
is there anything else i can do also to tune my v6 up i know all the vectra b v6 tuning tips but non of them work with the omega :( bored out throttle bodies made no noticible difference on the mig
« Last Edit: 04 May 2009, 22:01:58 by tmx »
