Author Topic: Shuttle PSU  (Read 2202 times)
Shuttle PSU
« on: 09 May 2009, 19:01:46 »
Anyone got a good source for these? I usually use ebuyer but they don't list them  :'(
Re: Shuttle PSU
« Reply #1 on: 09 May 2009, 19:03:52 »
Yuk! Shuttle cases!
Yup, you guessed it, they are on the gay list as well.
I'm guessing it may be cheaper to buy a new shuttle case, if thats the way your sexuality takes you
Re: Shuttle PSU
« Reply #2 on: 09 May 2009, 19:06:18 »
Yuk! Shuttle cases!
Was not my choice of purchase, just been given one and diagnosed a ducked PSU.
Best choice of supplier seams:
http://www.evercase.co.uk/PowerSupplyUnits.htm
Re: Shuttle PSU
« Reply #3 on: 09 May 2009, 19:13:03 »
Yuk! Shuttle cases!
is the system worth spending that amount on?
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Shuttle PSU
« Reply #4 on: 09 May 2009, 19:13:54 »
i built a shuttle for someone a few years ago i used www.overclockers.co.uk based in smoke on trent they supplied me with all the bits at goodish prices
mantahatch
Re: Shuttle PSU
« Reply #5 on: 09 May 2009, 19:19:12 »
I used to get given them by the bucket full from work. Sorry but got none left now.
Could I suggest before completly condemming the power supply that you check the power button on the front, had more than 1 of these go wrong. It ended up that evertime I got one I pulled the wire off the m/board from the powerswitch and briefly shorted the pins together, sometimes it worked and it was the faulty switch and sometimes it did not meaning faulty power supply.
By the way if you short the 2 pins for to long it will turn off again.
HTH
Mike
Re: Shuttle PSU
« Reply #6 on: 09 May 2009, 19:20:55 »
Yuk! Shuttle cases!
It would do as a print server, its not that old its got firewire ports on the front, not sure on its spec though.
Confirmed its PSU, bodged an ATX one on, turned on fine.
Re: Shuttle PSU
« Reply #7 on: 09 May 2009, 19:26:17 »
Yuk! Shuttle cases!
If using Intel netburst or AMD athlon chips, it won't be ideal for leaving on 24/7.  Actually, shuttle is too compromised to be on 24/7.
WoL probably won't be the answer either, as it will always keep waking up unless you use magic packets, which will be too much farting around
Re: Shuttle PSU
« Reply #8 on: 09 May 2009, 19:32:59 »
On the Gay list eh!
Says a lot about me then.
last count I had 7 of them scattered arrourd the house.   [smiley=2vrolijk_08.gif] [smiley=2vrolijk_08.gif]
Re: Shuttle PSU
« Reply #9 on: 09 May 2009, 20:18:43 »
Yuk! Shuttle cases!
Yeh WOL is too unreliable, its only going to be an office print server, father tunnie is the only one that prints, and the printer is in my room  >:(
Allenm
  • Milton Keynes
Re: Shuttle PSU
« Reply #10 on: 09 May 2009, 20:42:18 »
Yuk! Shuttle cases!
Move the printer onto your dad's machine then!
Re: Shuttle PSU
« Reply #11 on: 09 May 2009, 20:48:32 »
Yuk! Shuttle cases!
Wish is was that easy  ;D
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Shuttle PSU
« Reply #12 on: 09 May 2009, 20:56:35 »
try http://www.scan.co.uk/ never had a problem ad the prices are normally good :y
Re: Shuttle PSU
« Reply #13 on: 09 May 2009, 23:02:26 »
On the Gay list eh!
if the cap fits ;D
Re: Shuttle PSU
« Reply #14 on: 09 May 2009, 23:03:42 »
Stopped using them scumbags a while ago, due to making warranty claims hard work and time consuming :(.  Still, not quite as bad as Bluepoint....
