Author Topic: Noisy Nissan!  (Read 1289 times)
Noisy Nissan!
« on: 13 May 2009, 11:35:54 »
Brother in law has a Nissan Vanette Cargo 2.3 which he uses for work.It has developed an intermittent noise which he describes as sounding like 2 metal discs rubbing together,the noise stops when he pushes the clutch pedal down.First thing that sprung to mind was the clutch release bearing but he had a complete new clutch fitted 2 days ago and the problem is still the same as it was.Anyone got any ideas? :-/
Omega man 2
Re: Noisy Nissan!
« Reply #1 on: 13 May 2009, 11:37:40 »
Only thing I can think of is a problem with the flywheel :-/
Happened to me a while back, only there was a horrible grindng sound while pressing the clutch
Re: Noisy Nissan!
« Reply #2 on: 13 May 2009, 12:28:34 »
Gearbox input shaft?
mantahatch
Re: Noisy Nissan!
« Reply #3 on: 13 May 2009, 12:46:42 »
Is he sure they fitted a release bearing when doing the clutch ? It would not be the first time it was "missed"
Re: Noisy Nissan!
« Reply #4 on: 13 May 2009, 12:55:20 »
Yes,it had a new bearing fitted. :y
Re: Noisy Nissan!
« Reply #5 on: 13 May 2009, 12:57:34 »
sounds plausible,thanks. :y
STMO123
Re: Noisy Nissan!
« Reply #6 on: 13 May 2009, 12:58:20 »
Tell him to turn the radio up, that usually cures bad noises :y
Unless he puts radio 1 on, then it will get worse.
Re: Noisy Nissan!
« Reply #7 on: 13 May 2009, 13:04:37 »
 :y ;D ;D ;D
Page created in 0.008 seconds with 16 queries.
