Author Topic: paraffin  (Read 3981 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
paraffin
« on: 15 May 2009, 13:37:58 »
went on to google & typed in " diesel injector cleaner " hoping i,d find a link to suggest which products best. i saw a link leading to a guy say ing that he he uses paraffin . that then led me to a alpha romeo forum & upon reading the posts it seems loads use it, a cupfull to a tank every 3k miles  incidentally the guy is a lab tech  :-/ :-/ :-/
unlucky mark mv6
  • tipton,west mids
Re: paraffin
« Reply #1 on: 15 May 2009, 16:28:30 »
Iknow they used to use it years ago degrease the engine components,but not heard of putting it in your tank. :-?
raywilb
    • Citroen C4 Cactus
Re: paraffin
« Reply #2 on: 15 May 2009, 17:24:12 »
yes just tried it again -googled " which injector cleaner" and saw a link for home-made cleaner. alfa romeo forum. i,ll try it anyway.  :y
Re: paraffin
« Reply #3 on: 15 May 2009, 17:26:44 »
I do not understand this one! ::) ::)
With every gallon of fuel the engine burns it produces some pretty horrible by products like sulphuric acid and paraffin.  Admittedly once the engine is at full temperature most of these nasties are (hopefully) burnt off, but the engine inevitabitily receives a steady dose of paraffin anyway, so why add to it? ::) ::) ;)
« Last Edit: 15 May 2009, 17:58:43 by Lizzie_Zoom »
raywilb
    • Citroen C4 Cactus
Re: paraffin
« Reply #4 on: 15 May 2009, 17:35:04 »
all i was trying to do was find out the best injector cleaner to use and stumbled across the paraffin job    :) :)
Re: paraffin
« Reply #5 on: 15 May 2009, 17:37:17 »
Yes I understand that and it is an interesting one. :D :D :y  I would certainly recommend a standard injector cleaner from Halfords! 8-) 8-) ;)
Re: paraffin
« Reply #6 on: 15 May 2009, 17:57:08 »
Diesel Magic is the stuff I used to use in my tractor - only neat and in fuel filter.
I used to use Diesel Redex in tank if I was using Supermarket crappy fuel.
Both have OKish discounts from Halfords if you have a Halfords Tradecard
Omegatoy
  • UK
Re: paraffin
« Reply #7 on: 15 May 2009, 19:44:04 »
lol it does have some merits actually,
I know of a guy who has only run his Omega td on used hydraulic oil that he mixes with parafin to get the same drop rate as diesel, and so far he has done 83k on it with the only difficulty being it takes 3 goes of glow plugs to get it to fre on a cold winters morning ;D but he gets the hydro oil free so he isnt to bothered!!
in point of fact kerosene would be better but its virtually the same stuff ,
small quantity of lpg also allows the fuel efficiency to rocket cleaner better burn and more power and economy!! :y
Re: paraffin
« Reply #8 on: 15 May 2009, 19:53:01 »
I was always under the impression kerosene was American for paraffin.  :-/  :-/  :y
Re: paraffin
« Reply #9 on: 15 May 2009, 19:55:24 »
Isn't kerosene mainly used in aviation? :-?
Re: paraffin
« Reply #10 on: 15 May 2009, 19:57:11 »
IIRC We  put 'Avcat' in our helicopters ...... :-?
waspy
Re: paraffin
« Reply #11 on: 15 May 2009, 20:07:16 »
Where's Debs? Debs would know :)
Omegatoy
  • UK
Re: paraffin
« Reply #12 on: 15 May 2009, 20:07:44 »
jets run on kerosene, its also called avgas, diesels will burn it quite happily!! :y
Re: paraffin
« Reply #13 on: 15 May 2009, 20:17:20 »
........  its also called avgas,  .....
I've heard of that too! ;) ;D
Re: paraffin
« Reply #14 on: 15 May 2009, 21:13:11 »
Avgas is 100 octane leaded petrol for piston engines. Kerosene is known as Avtur and Jet-A1 IIRC.
