Author Topic: just sheared the star drive nut on the EGR valve  (Read 832 times)
Plomien
  • Swansea
    • Landrover Freelander TD4
« on: 16 May 2009, 17:02:27 »
took the EGR off as it needed a clean after being advised it was causing the eml light to come on occasionally.
sorted the egr our and working fine but when I was tightening everything it sheared the top off.
So scrappy visit me thinks to get a replacement, once i get the old bit out. for now its secure with one nut anyway :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: just sheared the star drive nut on the EGR valve
« Reply #1 on: 16 May 2009, 17:58:06 »
Drill it and tap it to 8 mm I think from memory, doesn't matter if you put a torx headed bolt in or a normal headed bolt then :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2 on: 16 May 2009, 18:59:06 »
you maybe able to drill the centre & use an easy out if you have any. just an idea.  ;)
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #3 on: 16 May 2009, 19:08:19 »
Being as the bolt has snapped, it shouldn't be too tight. You might be surprised to find it'll come out with your fingers! Or maybe a good set of pliers/mole grips to get it started.
Good luck.
best wishes
Simon.
waspy
« Reply #4 on: 16 May 2009, 19:17:34 »
Good luck.
Agreed. I don't know what access you have on the V6, but if you've enough. Hack saw the snapped stud to give you a slot for a flathead screw driver. This has got me outa the poo a few times :)
