Author Topic: Vectra 2.5 V6 CD  (Read 1747 times)
Mikejr
  • London
Vectra 2.5 V6 CD
« on: 17 May 2009, 17:22:05 »
Not strictly Omega I know but my son's thinking about buying one.
Is it the same engine as the Omega and therefore does it suffer from the same problems re blocked breathers leading to cam cover gasket failure etc.?
2000 Silver Omega Elite 2.5
HGV mechanic
  • northamptonshire
  • he just keeps on going,,,
Re: Vectra 2.5 V6 CD
« Reply #1 on: 17 May 2009, 17:32:00 »
the same engine but has the similar problems, not as quick to
    • 530D M Sport, 330i Coupe
« Reply #2 on: 17 May 2009, 19:53:59 »
Different camcovers with a 'beefier' cam cover gasket design so tend not to leak (but other seals will!).
Watch out for rear suspension bushes, no big deal but special tool required to fit them.
HGV mechanic
  • northamptonshire
« Reply #3 on: 17 May 2009, 21:52:53 »
dreaded rose bushes?
« Reply #4 on: 17 May 2009, 21:55:47 »
vectra has metal cam covers, cam cover gaskets not an issue, but must keep the breathers clean as it does not have gaskets to blow on the cam cover, the crank case oil seal goes
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #5 on: 17 May 2009, 22:51:15 »
DONT BUY ONE! is my bestest advice i can give you having owned two!
They are quicker than an omega 2.5 they will muller an Auto MV6 Estate having raced my old one against an one
they have a few inherant problems the cam covers are metal and so dont leak like an omegas one does instead it blows the rear crank seal contaminating the clutch and killing it
they are nowhere near as reliable as the omega for some unkonown reason! they have inherent flatspots down to bad manifold design
imho theyre good for 100k before the crankseal goes the clutch isnt an easy job atall you need a ramp front subframe job
« Last Edit: 17 May 2009, 22:53:01 by tmx »
doz
  • Southampton
  • LC,GSi Carlton,Omega Elite
« Reply #6 on: 17 May 2009, 23:20:21 »
and it's a right t*t trying to get access to do the cambelt. I had sri version it was fun-ish but it's front wheel drive also it was really noisey inside
Mikejr
  • London
« Reply #7 on: 18 May 2009, 18:50:07 »
Many thanks to all who replied, he did go to look at one but the guy had only bought it himself in April, also he couldn't find the V5  although he had a dvla receipt where he'd requested a new one. His reason for selling was that it was to expensive to get his girlfriend insured - yeah right -  at least my son had the sense to say No.
I will warn him off looking at others so thanks again.
BERTIECBX550
« Reply #8 on: 18 May 2009, 19:01:37 »
Theres nowt wrong with veccy`s they are plentiful and spares easy enuff to find and i always found them very reliable and decent cars to drive....I sometimes wished that i had never sold mine.... :y
unlucky mark mv6
  • tipton,west mids
« Reply #9 on: 18 May 2009, 19:04:29 »
Get a vec sri 150 2.2,cracking motor,and easy to work on. :y
« Reply #10 on: 18 May 2009, 20:51:18 »
Cambelt is easy on a Vec V6!
They suffer breather issues just like any other....but as said, it blows the crank seal!
Clearly not an issue if well serviced and kept clean.
No worse than any other car of that era
« Reply #11 on: 18 May 2009, 20:56:22 »
I know its only a saloon, but my auto mv6 slaughtered the 2 people I know with a 2.5 veccy-b
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #12 on: 18 May 2009, 22:35:44 »
yeah i raced a 3.0 auto explod and mullered it although my vectra wasnt the normal 2.5 ;) expolice model had G cams in it (fitted by the previous owner i bought it off vvoc)
i dont have a clue why but they are soo unreliable compared to the omega considering they both have the same engine sadly i killed my'n deliberatly as i hated it and the clutch had the slipping problem
mkaminski100
  • Basingstoke
« Reply #13 on: 19 May 2009, 12:50:20 »
Some people really don’t like Vectras. Well, it’s the same engine but you will never have any problem with leaking covers (aluminium ones). Cheap gaskets are ok for this one.  Breathers problem? Breathers in Vectra are not going through sh... plastic cover, so there’s nothing to get blocked. Yes, after some years, nozzles might get blocked but it takes 2 minutes to clean then (don’t have to undo throttle body).
It takes bit longer to do the cam belt but nothing serious, especially that there are no trumpets to be removed. I must say that for me it’s better to adjust the cam belt.
2.5 is bit too slow, just because the flywheel is too heavy – ca 15kg, but can be skimmed and it gives a better performance. I am quite sure that Omega manual uses the same flywheel. Omega has few HP more just because longer and bigger inlet and double exhaust. You can always swap 2.5 with 3.0 engine...
Front and back suspension might be a problem so avoid vectras with tilted back wheels (like that /- -\ ).
Clutch is a pain. Most garages advice to remove the whole subframe to do it, but many can do by only pulling the gearbox.
Petrol consumption: mine is doing 39 MPG on the run (real consumption is 37.5), and 28 urban (real is 25).
This car is not as comfortable as Omega, it does not turn like omega and does not run like one, but it’s still a good and reliable. Omega for me is like a wife – gives you 20% of passion and 80% of pain and all you know that there’s something wrong but you never know what the cause. The more you try to fix it, the worse it goes...There is no passion in Vectra but there’s also no disappointment. If it’s broken, you know what it is and you’ll fix it.
It’s just my private opinion after having 3 Omegas and 3 Vectras.
