Author Topic: Wish me luck  (Read 2204 times)
Wish me luck
« on: 19 May 2009, 08:05:13 »
Going to do my rocker cover gaskets today booked a days holiday for it too  :-/
jimmas
  • stevenage, herts
Re: Wish me luck
« Reply #1 on: 19 May 2009, 08:06:10 »
good luck, hope everything goes smoothly  :y
Miggy24
  • Exeter,Devon
Re: Wish me luck
« Reply #2 on: 19 May 2009, 08:08:29 »
Good luck you should be fine  :y
Richie London
  • heathrow
Re: Wish me luck
« Reply #3 on: 19 May 2009, 08:11:08 »
good luck mate. nice little job to keep you busy. maybe a couple coins for the swear box  ;D ;D
Re: Wish me luck
« Reply #4 on: 19 May 2009, 08:14:13 »
Defiantley, i've started stressing already and I ain't even started it yet, will crack on in about an hour.
Richie London
  • heathrow
Re: Wish me luck
« Reply #5 on: 19 May 2009, 08:16:19 »
its the wiring side i dont like, mine leaked the 1st time after a few miles. you live and learn. just make sure you take extra care doing that side  ;)
Re: Wish me luck
« Reply #6 on: 19 May 2009, 08:25:14 »
Will do mate  :y
Re: Wish me luck
« Reply #7 on: 19 May 2009, 08:25:55 »
Good luck  :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Wish me luck
« Reply #8 on: 19 May 2009, 08:47:08 »
take your time with it, dont forget the black snot & you should be ok.  :y
Re: Wish me luck
« Reply #9 on: 19 May 2009, 09:04:33 »
I forgot that !! I hope I have some in the garage somewhere.
The Red Baron
Re: Wish me luck
« Reply #10 on: 19 May 2009, 09:07:29 »
knew i would be usefull one day. ;D ;D ;D
Re: Wish me luck
« Reply #11 on: 19 May 2009, 09:15:08 »
Start now and you will be finished by 11.00 am Monday.
« Last Edit: 19 May 2009, 09:16:03 by Auto_Addict »
crazyjoetavola
Re: Wish me luck
« Reply #12 on: 19 May 2009, 10:50:04 »
 ;D ;D ;D :y Good luck anyway LSG :y
Re: Wish me luck
« Reply #13 on: 19 May 2009, 13:25:50 »
Hope all has gone well LSG! :y :y :y
It is a very job that is very satisfying..........apart from, as you say, the right hand passenger bank! Grrrrrrrrr ::) ::) ::) ::)
Bumbazor
  • Worksop
Re: Wish me luck
« Reply #14 on: 19 May 2009, 13:43:30 »
....the right hand passenger bank! Grrrrrrrrr ::) ::) ::) ::)
Mine wasn't too bad when I removed the scuttle cover and the cable tray, and pulled the wires out of the way.
