Pages: 1 2 3 [4] 5  All   Go Down
Author Topic: Another Quality TheBoy production  (Read 8045 times)
Re: Another Quality TheBoy production
« Reply #45 on: 27 May 2009, 13:34:42 »
CID is the right one for my car and when the CID is fitted everything works fine even stereo and BC functions the only problem i get is display safe pops up every 2 or 3 seconds
Sounds like right screen. Not sure if it will have right config code on, sadly I can't resolve that without my CANdi lead if it has the wrong config code (in which case, BC will be wrong)
bigmac
  • Devon
« Reply #46 on: 27 May 2009, 13:37:24 »
Not to bothered about BC functions atm just need to stop display saying "display safe" once its paired i will get all the code indexs and BC set.
Are you able to get code from radio then  :'(
« Reply #47 on: 27 May 2009, 13:40:52 »
I cant see that part no in EPC....only a couple of numbers away from the Vectra Colour displays though  :-/   13156088
cant find the omega number either?
bigmac
  • Devon
« Reply #49 on: 27 May 2009, 13:44:32 »
Should be able to.
bigmac
  • Devon
« Reply #50 on: 27 May 2009, 13:46:47 »
Brill i have pm'd you my mobile number give us a ring or text and i will ring you straight back
all so is there any way to tell if the CID is still married/paired to another stereo
« Reply #51 on: 27 May 2009, 14:11:46 »
Only way to tell is live data reading on the CID when fitted.
bigmac
  • Devon
« Reply #52 on: 27 May 2009, 14:16:03 »
So would a vauxhall techy be able to tell thats the question.
And say it was still paired would that mean its useless or could you pair it with my stereo.
Any chance i could pop over tonight or tomorrow  :-[ or am i being to pushy as i was meant to be leaving tonight but could stay an extra couple of days if i know i can get this sorted
« Reply #53 on: 27 May 2009, 14:57:47 »
Tech2 can tell current status, select CID, then check Data Display, and it will say something like:
Delivery State - all well in the world
ID NOK (Yet) - up a smelly inlet, with no oar
If the latter, the screen is a doorstop, unless someone has a blank image for one.
I can discover pairing code tonight, should be in around 5:30ish, as I'm leaving work earlier today. I'm in Brackley - the other end of Northants to where you are.
« Reply #54 on: 27 May 2009, 14:58:37 »
Sadly, do have to make a charge for discovering code to put in my Tech2 fund to offset the costs of them  :'(
bigmac
  • Devon
« Reply #55 on: 27 May 2009, 15:00:02 »
Im in corby atm its about an 1hr a way from brackey if you send me you addy i will try and meet you there around 5.30 ish if thats ok
Thats fine about the charge mate any ideas of how much ? as i will need a ncdc2015 doing in a few days as i have one at home thats not been depaired :( plus i will put a good word for you on our forums www.vectra-c.com
« Last Edit: 27 May 2009, 15:01:50 by bigmac »
« Reply #56 on: 27 May 2009, 15:11:34 »
Price column 2 on http://theboy.omegaowners.com/tech2/prices.shtml is what I normally say - this one is more of an unknown as having to do without tech2 due to MDTM having my CANdi, so say £20 and we'll cover as much as we can cover?
Address arriving shortly via PM.
bigmac
  • Devon
« Reply #57 on: 27 May 2009, 15:13:53 »
Cheers just off phone with techy at vaux he seems to think the CID is ok as its asking for the code for stereo but not holding my breath
« Reply #58 on: 27 May 2009, 15:26:00 »
I hope you have some stereo removal keys - I've lent my double din ones out  :'(
bigmac
  • Devon
« Reply #59 on: 27 May 2009, 15:27:10 »
Stereo is easily removed mate
Pages: 1 2 3 [4] 5  All   Go Up
Page created in 0.027 seconds with 16 queries.
