Pages: 1 2 3 4 [5] 6 7   Go Down
Author Topic: Project Heads Off  (Read 10730 times)
Martin_1962
Re: Project Heads Off
« Reply #60 on: 25 May 2009, 15:37:12 »
Ralttling worse and misfiring now
1500
0339 for starters
« Reply #61 on: 25 May 2009, 15:40:39 »
P1500   Electronic Throttle Control Motor Failure
cant find 339 yet
« Reply #62 on: 25 May 2009, 15:41:56 »
nearest are
P0335   Crankshaft position sensor "A" circuit malfunction
 P0340   Camshaft position sensor circuit high input
Taxi_Driver
« Reply #63 on: 25 May 2009, 15:55:24 »
All the connectors plugged in correctly and in the correct places?
Martin_1962
« Reply #64 on: 25 May 2009, 16:28:11 »
ALl look like it
135 is noisy - not sure if lifters of duff supply of oil
They look quite dry
Can someone post us a picture of a head gasket please?
webby23
  • Nottingham
  • MV6
« Reply #65 on: 25 May 2009, 16:41:37 »
0339
Crankshaft Position Sensor A CKT Internittent
Martin_1962
« Reply #66 on: 25 May 2009, 16:56:43 »
Cable looks OK?
Martin_1962
« Reply #67 on: 25 May 2009, 19:53:20 »
I'll worry about those after I have got the 135 head sorted properly.
Martin_1962
« Reply #68 on: 26 May 2009, 18:07:08 »
Runs OK now, not sure if the gasket will last or not, got a spare on the way from Trechii along with the bolts, the tappets survived no oil and so did the cams, head was a little damaged but is OK.
Seems to go better, better than it did but not quite right, might just need time to adapt.
Got a few error codes.
1500
0330
1500
1522
Plus some misfire codes from when the evaporator went wrong.
Spanner light is on (bottom left) the one which flashes when you do the two pedal trick.
All left to do is refit scuttle, wipers and reconnect LPG
Martin_1962
« Reply #69 on: 26 May 2009, 18:41:03 »
So my crank sensor might be on last legs?
Hmm more expense!
Martin_1962
« Reply #70 on: 26 May 2009, 19:56:10 »
Just refitted wipers, also fault light has gone out.
One more job is to reconnect the LPG manifold temperature sensor
« Reply #71 on: 26 May 2009, 21:26:51 »
Did you re use the gasket and bolts Martin?
Martin_1962
« Reply #72 on: 26 May 2009, 21:28:21 »
Yes but replacements are on the way
« Reply #73 on: 26 May 2009, 21:30:26 »
Crikey, you'll be a dab hand at changing that 135 head gasket, at this rate  ;D ;D
Martin_1962
« Reply #74 on: 26 May 2009, 21:48:09 »
It's a pig of a job, got back to bolts out last night, took me about 7 hours to finish today.
Found a few tips.
Don't unbolt the exhaust - jack it.
Coolant pipe, unbolt that then the bracket from head.
Undo oil coolant pipes from cooler and they spring up enough to spend 30 minutes a bolt undoing from the back of the block.
I reckon I spent about 1.5 hours alone on this pipe.
My hands are a funny size, quite wide but short fingers.
How do you shift this pipe quickly?
Oil cooler is easy to change if you remove 246 head as you can get to one pipe with a 19mm spanner.
246 is a lot easier to remove, even if you have to saw off the dip stick tube bracket.
Pages: 1 2 3 4 [5] 6 7   Go Up
