Author Topic: Piston trouble.....  (Read 1734 times)
Piston trouble.....
« on: 06 June 2009, 19:54:53 »
....no not on a miggy, but on the Standard 5 4-6-0 73096 on the Mid Hants Railway!
You may think you have problems when the cam belt breaks, but this is what can happen on a steam railway engine when apparently a cylinder core-plug breaks loose and gets in the way.......!!! :'( :'( :'( :'( :'(
Re: Piston trouble.....
« Reply #1 on: 06 June 2009, 19:58:08 »
Ooops!
I've never really thought about it before, but what kind of steam pressures & temps are we talking about from a stm train loco?
In English units please!  ;)  ;)  ;)
« Reply #2 on: 06 June 2009, 20:00:34 »
ooooo, thats looks painfull :-/
KillerWatt
« Reply #3 on: 06 June 2009, 20:04:51 »
Ooops!
F**king s**t loads
« Reply #4 on: 06 June 2009, 20:06:10 »
Ooops!
On average, depending on the type of engine you are talking about 250 psi at 405 degrees fahrenheit, but 300 degrees higher if using superheated steam, with say bulleid pacific classes being run at 280 psi at 750 degrees F., superheated.
nick v6
  • walsall / west midlands
« Reply #5 on: 06 June 2009, 20:12:26 »
oh my god
i bet that went with a bang :o
ive never seen anything like that before
« Reply #6 on: 06 June 2009, 20:16:44 »
Ooops!
I hate dislike steam! It can be nasty stuff - as your photo shows - it used to amaze me in my days of the Grey Funnel Lines when people, who should have known better, would go searching for superheated steam leaks with the back of their hand! :o
We used to steam at 550psi 850oF
And they are reluctant to work on the wet soggy low pressure stuff we have at work.  ;)  ;)  :y
« Reply #7 on: 06 June 2009, 20:26:32 »
Ooops!
Yes Andy, it must be treated with great respect! ;) ;)
Your great fear on the footplate, apart from blowbacks from the firebox, is that the drain cocks are not fully opened with steam blown through, before applying the regulator after a stop.
Any water in the cylinder can destroy it, or at least blow the cylinder covers off, when the piston pushes against said water, as water cannot be compressed!!  Very nasty!! :o :o :'( :'( :'(
« Last Edit: 06 June 2009, 20:26:54 by Lizzie_Zoom »
Martin_1962
« Reply #8 on: 06 June 2009, 20:44:07 »
Very expensive
New casting required
« Reply #9 on: 06 June 2009, 20:48:27 »
It's OK it's old, think of the scrap value......... :y
« Reply #10 on: 06 June 2009, 20:59:12 »
Ooops!
Nothing in comparison to what's going on in a car engine, but if something goes wrong, it 'aint going to stop.
The mind boggles at the sort of forces that must have been involved in that failure. I doubt those connecting rods bent desperately easily. :o
ally_cover_expert
« Reply #11 on: 06 June 2009, 21:01:55 »
Pissed and broke :)
