Author Topic: USB Turntable  (Read 1779 times)
Olympia5776
  • Ireland
USB Turntable
« on: 09 June 2009, 12:11:23 »
http://www.aldi.ie/ie/html/offers/2867_9314.htm
I've been thinking of getting one of these for some time now .They are freely available on E Bay for not much money .
Anybody got or used one and can tell me if they are any good ?
Alternativly
http://www.nch.com.au/golden/index.html
Re: USB Turntable
« Reply #1 on: 09 June 2009, 12:14:49 »
Alternativly
 ;D ;D ;D ;D ;D ;D
Sorry thats almost as good as the USB Cup Warmer
unlucky alf
  • worksop, notts
Re: USB Turntable
« Reply #2 on: 09 June 2009, 12:31:47 »
ive got a normal record deck [aiwa]on mine with a built in pre-amp,[found for £1 on fleamarket] i then run it through "audiolab" software & plugged into my soundcard with a 2xphono to 1/4 jack lead, if you go to a market etc looking for one then lift the rubber plateu, rotate the turntable & look through the hole in the deck itself, if you see a switch then it has a pre-amp which will make it easy [aiwa tend to have them],it is generally mounted towards the back of the unit failing that you can buy a pre-amp for not too much money :y& the software is available on d/load sites, it even can take out pops & scratches,,,hope that helps :y :y
Olympia5776
  • Ireland
Re: USB Turntable
« Reply #3 on: 09 June 2009, 13:05:10 »
Thanks Alf.
I've got a Sansui  turntable with good quality stylus stored away along with the albums.
It was part of a " seperates " system but I bought an in line pre amp to play it through the auxiliary input of the current system we use so that looks to be the way forward.
Cheers
Don
Re: USB Turntable
« Reply #4 on: 09 June 2009, 13:13:37 »
Thanks Alf.
Cheers
Don
Yup, as long as its an RCA pre-amp and not a linear.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: USB Turntable
« Reply #5 on: 09 June 2009, 13:39:10 »
Laser Turntables might be an idea for Archiving old collections.
Re: USB Turntable
« Reply #6 on: 09 June 2009, 13:51:09 »
If you have a turntable, a (pre-)amp or something that'll turn the cartridge output into a line level signal and perform RIAA equalisation and a sound card to feed the line level signal into (sounds like you do) then the USB turntable won't gain you anything.
I haven't heard the results from one but they look like the cheapest, nastiest turntable you could imagine so I would imagine the resultant audio files don't sound great.
How well it works depends on how good your sound card is. Some are truly awful and some are surprisingly good. I have recently bought an M-Audio Transit for another project and been surprised how good a job it does.
Olympia5776
  • Ireland
Re: USB Turntable
« Reply #7 on: 09 June 2009, 14:00:11 »
This one.
Edit.
Dell PC /Soundcard with Dolby Digital 7.1 capability.
« Last Edit: 09 June 2009, 14:05:15 by olympia5776 »
unlucky alf
  • worksop, notts
Re: USB Turntable
« Reply #8 on: 09 June 2009, 14:13:05 »
just the job, the software i use is magix audio cleaning lab, i believe its available on piratebay ;) ;)
BERTIECBX550
Re: USB Turntable
« Reply #9 on: 09 June 2009, 14:25:47 »
HMMM wheres me old maiden and metal LP`s...... ;D ;D ;D
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: USB Turntable
« Reply #10 on: 09 June 2009, 16:56:03 »
Kevin's right.  If you have a moving magnet pickup on your Sansui you do need RIAA equalisation otherwise it will sound v poor.  The preamp shown does not appear have that.
I would not buy the USB thing if I already had a half-decent separate.
[edit]Correction: My preamp is the same make/model as yours.  It's silver though[/edit]
« Last Edit: 09 June 2009, 16:58:55 by ChrisH174 »
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
KillerWatt
Re: USB Turntable
« Reply #11 on: 09 June 2009, 22:42:28 »
The reason they are freely available for not much money is because they are cack (as is the crap software that accompanies them).
Re: USB Turntable
« Reply #12 on: 09 June 2009, 22:52:20 »
I'd say that preamp does have RIAA equalisation. It's clearly designed to take a phono (or mic) input.
Have a listen to a turntable through it and see how it sounds.
Olympia5776
  • Ireland
Re: USB Turntable
« Reply #13 on: 10 June 2009, 07:44:16 »
I've used it many times playing it through a later stereo with auxiliary input and it sounds very good .
I'll have it up and running at the weekend ,all being well.
Thanks
