Author Topic: Tech 2 on Ebay  (Read 4289 times)
cornishtaz
  • Lyneham, Wilts SN15 4DZ
Tech 2 on Ebay
« on: 15 February 2007, 11:03:13 »
Has anyone purchased or used one of the Tech 2 interface modules that are advertised on ebay.
Like this one
http://cgi.ebay.co.uk/TECH2-Diagnostics-KIT-for-Vauxhall-tech-2-UK-Seller_W0QQitemZ110089727970QQihZ001QQcategoryZ30921QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
If so are they any good.
« Last Edit: 15 February 2007, 11:29:56 by cornishtaz »
    • E250 Est / Elroq
Re: Tech 2 on Ebay
« Reply #1 on: 15 February 2007, 11:12:46 »
You mean :
(your link doesnt work, 3 x http://'s doesnt help)
Ive got one, as have several people on here.
They are OK is the answer
Software is buggy and 1/2 hungarian!
need a reasonably powered laptop with a real COM port, they dont like adaptors
They can read and reset faults, including airbag
Seem intermittant on which cars and systems they work with.
Consensus is if they reset 1 fault for you, it has paid for itself.
To help searching, look for 'cheapo tech 2' or 'poor mans tech 2'
« Last Edit: 15 February 2007, 11:15:43 by jimbob »
Re: Tech 2 on Ebay
« Reply #2 on: 15 February 2007, 12:50:54 »
This is something I am still working on myself....
I have now created most of the error code files in english (the software defaults to hungarian if it cant find the english error code files) and I am slowly (when time permits) editing the Opeldata file to add the new fault lists in......
Then its a case of filling in the blanks for baud etc and its should be much improved.....
    • E250 Est / Elroq
Re: Tech 2 on Ebay
« Reply #3 on: 15 February 2007, 13:18:30 »
Mmmmm
I gather it is still a work in progress.....but fancy sharing it out?, I'm sure a lot of us would benefit from your hard work.
Re: Tech 2 on Ebay
« Reply #4 on: 15 February 2007, 13:24:41 »
Its on my home PC so will need to wait until this eveing.
I have edited a few files, details are:
Main ECU file now only covers OMEGAB (you get no other options as it makes it easier for me to work on).
When you select English the main screen says Vauxhall and not Opel so you now know the language setting is correct.
I have created most of the ECU files.
Currently only worked on 1998....one step at a time.
To do, test it and debug as required, check pin numbers are correct, finish writing the fault codes files...
So its not realy ready to go yet.....
    • E250 Est / Elroq
Re: Tech 2 on Ebay
« Reply #5 on: 15 February 2007, 13:29:43 »
Good work fella!
And a excellent year to start on ;)
If you need a beta tester.....just let me know :)
Re: Tech 2 on Ebay
« Reply #6 on: 15 February 2007, 14:07:26 »
The majority of the 98 stuff will cut and paste into the other years, I would need to add some engine varients etc to.
Ronald_McBurger
Re: Tech 2 on Ebay
« Reply #7 on: 15 February 2007, 15:12:22 »
I think they are great! I used one on mine and it told me that the Goulash was gangle pinned to the waffle iron. That will be 40,000 rubettes please. front row, after kenn Dodd.
Nothing wrong with them ::)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Tech 2 on Ebay
« Reply #8 on: 15 February 2007, 16:43:31 »
The fact that it resets my airbag light has more than paid for itself for me.
Saves me having to fork out stupid dealer prices.
.....and it also saves me from making a nuisance of myself with TheBoy.
I like red cars
Re: Tech 2 on Ebay
« Reply #9 on: 15 February 2007, 18:10:46 »
As I've said loads of times, if you have a reasonable spec laptop with a real COM1 port, then at £30 - £40 you can't go wrong. Obviously it cannot do as much as more expensive stuff, but thats understandable.  The software is utter rubbish, but mostly usable.
cornishtaz
Re: Tech 2 on Ebay
« Reply #10 on: 15 February 2007, 18:11:51 »
So the general concensus is their worth getting :y
Re: Tech 2 on Ebay
« Reply #11 on: 15 February 2007, 18:17:16 »
If you have a reasonably powerful laptop capable of running it...
iggy21uk
  • Berkhamsted - Herts
  • Omega Spotter -  tats gone tanning
Re: Tech 2 on Ebay
« Reply #12 on: 15 February 2007, 18:21:52 »
Anybody tried this version of the software for the opel tech2????
http://dohc.co.uk/z20let/downloads/OP-Tech2-English.zip
The Opel Autoscanner working ok but more expensive £200 +
should be getting a upgrade sooooon
also aldl cable  so that it can look at pre 97 cars
[size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/i][/b]
Ronald_McBurger
Re: Tech 2 on Ebay
« Reply #13 on: 15 February 2007, 20:51:41 »
Not tried that. But I do like Nescafe Gold blend though. Does that count?
iggy21uk
Re: Tech 2 on Ebay
« Reply #14 on: 15 February 2007, 23:34:40 »
yep!
