Author Topic: Computer problems, any help!  (Read 2169 times)
MickAP
  • South Derbyshire
« on: 28 June 2009, 14:30:30 »
My laptop is giving me grief. It's an Acer Aspire had it 18 months. The main problem is keeps freezing or saying internet page cannot be found when I'm browsing the net. A reboot gets it back but only lasts a few minutes then freezes up again. I'm using it on a wireless connection but it makes no difference because it still won't stay connected if I plug into the modem direct.
I am getting an internet connection, done all the checks (with another PC) check my firewall and anti-virus it's definately not the problem........it is defo the laptop problem, but what? Get the same probs with Firefox and Internet Explorer. Could it be a driver problem? Maybe a bug somewhere, I've done a virus check........I run AVG and Zonealarm which I have uninstalled then reinstalled but no luck.
Mick
« Last Edit: 28 June 2009, 14:31:58 by MickAP »
Banjax
  • Perth
Re: Computer problems, any help!
« Reply #1 on: 28 June 2009, 14:33:16 »
reverse over it with the mig, call your home insurance, and buy a macbook with the cheque, problem solved  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #2 on: 28 June 2009, 15:04:13 »
xp or vista ?
eddie
  • Cardiff
« Reply #3 on: 28 June 2009, 17:11:31 »
Is it possibly overheating? -can you expose the cpu fan/heatsink and give it a good blow job? :D
Other than that--
I believe there is a piece of software in the o/s that shows you what processes are running and what cpu time they are using up-maybe something is being greedy?
eddie
MickAP
  • South Derbyshire
« Reply #4 on: 28 June 2009, 17:40:23 »
xp or vista ?
It's Vista Premium.
Have been told, by some tech guys (sought of secondhand info) that there are problems like this with Vista. Everything else works fine, I've cleaned out any dust etc from around the vents etc.......it's just this internet freezing, I don't understand why.........was also told maybe something to do with the MAC address needs renewing.....anyone know about that?
Mick
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 28 June 2009, 17:56:05 »
are you running a registry cleaner ?
if not try and download TweakNow RegCleaner and run it  :y
also delete all your internet temp files  :y
Plomien
  • Swansea
    • Landrover Freelander TD4
« Reply #6 on: 28 June 2009, 18:05:18 »
download tuneup utilities 2009 it will sweep your system and fix any issues.
also check for spyware.
spybot search and destroy and adaware will sort the spyware issue out (if there is one)
« Reply #7 on: 28 June 2009, 18:37:19 »
agreed.. it seems  like an hardware problem..
probably not cooling the cpu enough or something worse :-/
webby23
  • Nottingham
  • MV6
« Reply #8 on: 28 June 2009, 19:05:45 »
Weirdly my web-book occasionally behaves the same way and the only thing I have in common with you is that I am also using AVG...........
Teebee
  • Slough
« Reply #9 on: 28 June 2009, 19:24:23 »
As someone cursed with doing this kind of support for a living without a specific error message or being in front of the machine any kind of diagnosis is tenuous at best.
What I tell people is go through the DVD's/manuals you got with the machine and look for a restore DVD, then back up all your piccies, files, programs, porn etc  ;) and run a complete reinstall. Then see how it goes, if the problem remains it's probably hardware related.
MickAP
  • South Derbyshire
« Reply #10 on: 28 June 2009, 19:32:58 »
I had to stop myself yesterday from getting the hammer to it, good idea though running the miggy over it.
Mick
semisheen
  • Chesterfield
« Reply #11 on: 28 June 2009, 21:36:12 »
xp or vista ?
It's Vista Premium.
Mick
Mac adresses NEVER get renewed they probably mean IP adress But this "wont"be your problem but if you wish to on vista type in "cmd"in the search bar (start / search) when its found double click it ....a black box will appear type "ipconfig /release"   this will release your ip adress ..then type "ipconfig /renew"...this will renew it
George  :y
Pete Elite
  • Uxbridge, Middlesex
« Reply #12 on: 29 June 2009, 02:10:50 »
I've been having the same problem with my desktop but only during this hot spell so took the side off and trained a nine inch fan onto it which drops the temp. from 39c to 32c and behaves itself now :).
 Try running SPEEDFAN and see what your core temp. is.
