Author Topic: Advice needed for in the garden  (Read 2014 times)
Big Fra
  • Motherwell
« on: 05 July 2009, 18:55:34 »
I need to remove a large concrete slab from my back garden so I can get a rotorvator in to turn over the earth.
What is the best way for removing/breaking this concrete up?
The concrete is around 6 inches deep.
Help please :)
Welung666
Re: Advice needed for in the garden
« Reply #1 on: 05 July 2009, 18:56:58 »
Hire a Hilti, hours of fun ;) :y
Bent valve
« Reply #2 on: 05 July 2009, 18:58:19 »
Hit it very hard several times with a sledge hammer and it will disintrdgate :y
Debs.
« Reply #3 on: 05 July 2009, 19:06:17 »
Totally agree; `life`s too short to be breaking 6" concrete manually.....an electro-pneumatic breaker will do it fast and renting one really isn`t expensive!;)
redelitev6
« Reply #4 on: 05 July 2009, 19:50:11 »
How large is large? if you can get a scaffold pole or such under one side,then lever it up a few inches and then get someone to hit the middle of the concrete,the thing should break up,as long as it's not reinforced! if it is reinforced, go down the road of getting a breaker -sooo much easier ;D
« Reply #5 on: 05 July 2009, 20:02:31 »
14ld sledge hammer....it will only take a few wacks!
« Reply #6 on: 05 July 2009, 20:03:37 »
is that about 6 or 7 kilo?  ::)  ::)  :y
« Reply #7 on: 05 July 2009, 20:06:16 »
terribly sorry old boy, I am a little tired.....if only they were sold as metric!
Mind you, one of the ones I have is older than me!
Big Fra
  • Motherwell
« Reply #8 on: 05 July 2009, 20:12:29 »
Yeah sounds like a plan. :y
Wot's a Hilti? :-?
« Reply #9 on: 05 July 2009, 20:16:14 »
You were the one that said you don't do Imperial units!!!  ;)  ;)  ;)  ;)
Sledge hammers come in 28 lb too don't they?
« Reply #10 on: 05 July 2009, 20:30:16 »
A hilti will be more easy..
not sure for neighbours though..
Bent valve
« Reply #11 on: 05 July 2009, 21:16:21 »
Wot's a Hilti? :-?
[/highlight]
 Its an electric breaker like a kango. they are ok for walls and thin concrete, but you wont make much impact on 6"stuff . if you dont want to sledgehammer it you can hire a hydraulic breaker which is similar to a pneumatic road drill but more portable :y
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #12 on: 05 July 2009, 21:21:12 »
Actualy Hilti is a trade name and they make alsorts of tools , go to a tool hire place tell them what you are trying to do they will  I am sure tell you the best tool for the job  :y
Big Fra
  • Motherwell
« Reply #13 on: 05 July 2009, 21:43:37 »
Ah, that makes things a little clearer.
Cheers very muchly all  :y
mantahatch
« Reply #14 on: 05 July 2009, 21:52:50 »
I would go for one of these http://www.brandontoolhire.co.uk/directory/prodView.asp?idproduct=99
I find the electric ones are not much good, one like above did my old garden path a treat.
