Pages: 1 [2] 3  All   Go Down
Author Topic: How Big Is Your Piston?  (Read 2505 times)
The Barge Captain
Re: How Big Is Your Piston?
« Reply #15 on: 08 July 2009, 00:18:18 »
You no doubt know this already Mark, but for the benefit of anyone also interested I have found the below link that gives a great account of Class 47 Falcon:
http://www.class47.co.uk/c47_feature_424.php
  ;) ;) 8-) 8-)
I'm not much into trains, but that was quite interesting.
« Reply #16 on: 08 July 2009, 00:22:35 »
Am not big into trains either , but have been wathing some of the "World's Biggest" series on Discovey.  Especially the Oil Tanker Engines.
http://www.darkroastedblend.com/2006/12/biggest-ships-in-world-part-3.html
« Reply #17 on: 08 July 2009, 08:14:09 »
A small 280mm diameter on a 12LDA28C in a 47....but there are 12 of them
Which gives Mark a maximum tactive effort of 62,000lbs :y :y
Well out rating the tractive effort at 39,667lb at 85% boiler pressure, of the 9F :'( :'( :'(
And hence why the demise of steam came about...... much lower maintenance, better availability, better fuel economy were all the bonus points for diesel (and even more so electric)
The Uk has no choice but to move away from steam.
Did you know they built a class 47 with twin Maybach engines (as per a Western) and electrical drive (look for Brush Class 47 falcon)...sadly scrapped now, it also had a water scoop to use the water troughs on the mainline to replenish the steam heat boilers water supply.
It was a prototype - nearer in design to a 31 - look at the bogies.
It was TOPS class 53 and was numbered 1200 when purchased from Brush by BR.
2800bhp and was better than a Western (srry Western fans)
Most were   ;D
« Reply #18 on: 08 July 2009, 11:56:02 »
For anyone working on their combustion engine pistons, the following is an example of a brand new one for a 9F 2-10-0 steam railway engine:
each one of the two cylinders fitted to the 9F's (except the Crosti boiler examples, which are another story!) had a diameter of 20 inches and a stroke of 28 inches, which with all the other specifications of this class gave a tractive effort at 85% of boiler pressure (250lb psi) of 39,667lb's.
This is the 9F, 92212, that is being overhauled on the Mid-Hants (The Watercress Line) Railway at Ropley which will soon have the piston fitted:
These freight engines formed a very successful class right at the end of steam on BR, with 9F 92220 Evening Star being the last steam engine built by British Railways in 1960 at the Swindon ex-GWR locomotive works. Now preserved it is one of nine, including 92212, when I last checked.
You haven't been to Ropley without popping in for a cup of tea, have you? :o
Then again, I was in Kent all weekend. ;D
Just looking for my mate spud in that picture. He's normally employed welding inside a firebox, though, and when he emerges he's well camouflaged!
« Reply #19 on: 08 July 2009, 18:34:11 »
No, afraid not Kevin as it is some way for a day's trip, so as a member (since 1977) I keep in touch via the internet and receiving the Mid-Hants News in the post!! 8-) 8-) :D :D :D ;)
« Reply #20 on: 08 July 2009, 18:35:46 »
Wonderfully big, sexy engineering on a grand scale, and those pistons are quite something else Skruntie 8-) 8-) :y :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #21 on: 08 July 2009, 19:17:15 »
Skruntie post pictures of big pistons several times a day! ;D
crazyjoetavola
« Reply #22 on: 08 July 2009, 19:28:54 »
I've been piston from heights of great significance on more than one occasion - does that count? :-/ :-/
Pitchfork
« Reply #23 on: 08 July 2009, 19:30:01 »
Groan ::)
crazyjoetavola
« Reply #24 on: 08 July 2009, 20:06:35 »
Groan ::)
....am trying to appeal to all tastes here PF  :P ;D ;D
« Reply #25 on: 08 July 2009, 20:10:15 »
Typical men! ::) ::) ::) ::) ::)
I start a thread on engineering and it turns into one on sexual parts!! ::) ::) ::) ;D ;D ;D ;D ;)
crazyjoetavola
« Reply #26 on: 08 July 2009, 20:16:36 »
....the two are co-related, Ms Zoom - a lot of men continually try to engineer their way around the relevant sexual parts of whomsoever ;) ;) ;D :-*
« Reply #27 on: 08 July 2009, 20:26:00 »
Shame then Zulu that they can't engineer durability and extended effective output!! ::) ::) ::) :D ;)
crazyjoetavola
« Reply #28 on: 08 July 2009, 20:36:39 »
....you've spotted the design flaw then, Ms Zoom? ;) ;) ;D
« Reply #29 on: 08 July 2009, 20:42:41 »
EH!!!!!!!!!    and you blame us.
Pages: 1 [2] 3  All   Go Up
