Author Topic: IIS + SMTP + MX Records = Help!  (Read 2829 times)
Ian_D
  • York
« on: 20 July 2009, 20:14:19 »
Firstly, I don’t even know if what I’m trying to achieve is possible.... ;D
I've got a home server running Windows 2003. It’s running IIS, and has the SMTP service running.
T'other day I put together some ASP code which I'm playing with to send emails - this works fine  :y
However, I've always wanted to know if I can receive emails through my server.
What do need to do with DNS records etc? My domain name is with 1&1. ISP is Zen with a static IP.
I’ve added an MX to my domain, which is hosted with 1&1, however I’m not sure what I should be typing in there really!  :-[
I've read somewhere that I need to set up PTR's, but the only place I can find to setup a PTR is in the DNS server settings on my server itself, or is this the correct place?
Anyone got any clues? :-/
[size=12]
  • Online Online
Re: IIS + SMTP + MX Records = Help!
« Reply #1 on: 20 July 2009, 20:27:08 »
The MX records need to point to your mail server
You should have the option to add about three addresses, in priority order...
« Reply #2 on: 20 July 2009, 20:53:11 »
Right, for basic mail, you need in DNS:
A/Host record - eg mail.mydomain.com - IP w.x.y.z
MX Record pointing to A record - mail.mydomain.com
For sending mail, you may need to add a TXT record for SPF - Microsoft have a great generation wizard on their site for building SPF records. Without SPF, your mails may get bounced as spam
Using IIS SMTP service for incoming mail presents on major flaw - it has no mailbox support, so it needs to forward elsewhere to somewhere that does have mailboxes
« Reply #3 on: 20 July 2009, 20:54:15 »
You have the option to create as many MX records as you like, from 1 to unlimited
  • Online Online
« Reply #4 on: 20 July 2009, 20:56:50 »
Agree - but not sure all ISP front end control panels allow you to do so?
« Reply #5 on: 20 July 2009, 20:59:34 »
Only the gay ones limit you. You old 'local' competitor being a true example of how not to do it.
That said, some places have a single MX, but round robin the A record its pointed at
Ian_D
  • York
« Reply #6 on: 20 July 2009, 21:05:54 »
right, so I need to create an A record for mail.domain.co.uk on my home server?
And then set the mx record with 1&1 to mail.domain.co.uk?
What would the email address be? anything@domain.co.uk, or anything@mail.domain.co.uk?
assuming the 'anything' can actually be anything since the smtp should put it all in the same folder?
[size=12]
« Reply #7 on: 20 July 2009, 21:09:00 »
The a record needs to be on your authoritative dns (likely to be same place as where you put MX record
You cannot recieve mail without furthr software, as it has to be delivered to a mailbox.
Ian_D
  • York
« Reply #8 on: 20 July 2009, 21:16:22 »
Cant find anywhere to add an A record  :-?
[size=12]
Ian_D
  • York
« Reply #9 on: 20 July 2009, 21:17:06 »
Ah...
Do I need to create a new sub domain then?
and stick the MX and A record under that?
[size=12]
« Reply #10 on: 20 July 2009, 21:26:00 »
Might be called HOST record.
« Reply #11 on: 20 July 2009, 21:28:46 »
Ah...
Until you have software to provide mailboxes, you can't do anything.
Microsoft's effort is the expensive, complex, but bloody powerful Exchange Server. If you nee Exchange help, let me know ;).  But there must be plenty of freeware mail servers than can do both SMTP and POP3/IMAP
Ian_D
  • York
« Reply #12 on: 20 July 2009, 23:42:09 »
Ah...
Aye, I will use some freeware for the mail boxes.
[size=12]
Ian_D
  • York
« Reply #13 on: 20 July 2009, 23:49:38 »
If I select 'domain.co.uk' and click DNS settings, all I get is IP Address (A-Record) - All I can type in here is an IP.
And Mail Exchanger (MX-Record) - for MX 1 / Priority (4 of)
Thats it. So the A record is my servers IP - It always has been. So if I type in mail.domain.co.uk in the MX record, how does that link to my server? Or will 1&1 somehow change that to mail.123.123.123.123? where 123=my servers ip.
Think im getting my wires crossed somewhere  :'(
[size=12]
Ian_D
  • York
« Reply #14 on: 20 July 2009, 23:59:03 »
Hmm.. not sure how / if this is working, but its getting closer... Just got this bouncing back...
This message was created automatically by mail delivery software. A message that you sent could not be delivered to one or more ofits recipients. The following addresses failed: <test@domain.co.uk> SMTP error from remote server after RCPT command:host domain.co.uk[123.123.123.123]:550 5.7.1 Unable to relay for test@domain.co.uk
So, my server must now be receiving it.
[size=12]
