Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Any Guesses?  (Read 7054 times)
Re: Any Guesses?
« Reply #30 on: 21 July 2009, 10:23:19 »
It will be going soon, so all will be revealed before too long!
fingers & toes crossed  :y
Debs.
Re: Any Guesses?
« Reply #31 on: 21 July 2009, 10:44:46 »
Pob luc! :y
unlucky mark mv6
  • tipton,west mids
Re: Any Guesses?
« Reply #32 on: 21 July 2009, 11:43:42 »
Brake pipes thoroughly greased, fingers crossed! :y
Did you grease your nipples?
Thought you might come and do that for me TB???????? ;) :-*
I just hope husbands and wives dont see these threads while your on about greasing eath others nipples. ;D ;D :-*
Debs.
Re: Any Guesses?
« Reply #33 on: 21 July 2009, 12:29:30 »
.....and? :-/
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
Re: Any Guesses?
« Reply #34 on: 21 July 2009, 12:48:50 »
SHE FAILED!!! :'( :'( :'(
'offside track rod end ball joint has excessive play' bugger bugger bugger!
Advisory items..
'offside rear tyre worn close to legal limit'
'nearside and offside rear subframe rubber bush deteriorated but not resulting in excessive movement'
'front nearside tyre worn on the outside edge'
she's not a happy bunny!
Been there, fallen over it!
Re: Any Guesses?
« Reply #35 on: 21 July 2009, 12:51:31 »
Well thats a nice quick easy and cheap fix
Re: Any Guesses?
« Reply #36 on: 21 July 2009, 12:52:40 »
I hope so....
Track rod ends
Outer joint RH (long) to '99                                     90510654       £51.00       £43.39       £31.21
Outer joint RH (long) from '00                                    9193099       £38.40       £32.67       £22.48
Outer joint LH (long) to '99                                     90510653       £51.00       £43.38       £31.22
Outer joint LH (long) from '00                                    9193098       £38.40       £32.67       £22.48
Outer joint RH (short)                                      90510652       £36.20       £30.81       £22.47
Outer joint LH (short)                                      90510651       £42.95       £36.55       £27.41
Centre tie rod assembly - exc. lowered sports chassis from '00                              90510648       £157.00       £134.25       £100.47
Outer tie rod assembly, RH to '99                                    90510649       £105.00       £89.28       £67.81
not quite sure what I want, any ideas?
much involeved to fit?
guess we are gonna need geometry after too
Re: Any Guesses?
« Reply #37 on: 21 July 2009, 12:54:00 »
Re: Any Guesses?
« Reply #38 on: 21 July 2009, 12:55:14 »
:o Sorry TB i'm closer than you, LJ i'm on my way ;D
Re: Any Guesses?
« Reply #39 on: 21 July 2009, 12:58:35 »
Right, after reading that guide the short and long pieces fit into place.
Judging by how wim struggled to adjust em, It's gonna be the full section I replace (the £60 odd quid one)
looks like a trip to vaux and machine mart for a splitter.
Debs.
Re: Any Guesses?
« Reply #40 on: 21 July 2009, 13:08:47 »
Advisory items..
Oh bum! :'(
No massive probs. on the list though; if you? he wasn`t at death`s door it`d be a couple of hours work. ;)
Re: Any Guesses?
« Reply #41 on: 21 July 2009, 13:12:30 »
Advisory items..
Oh bum! :'(
ive got a set of the rear bushes....but carlton fit instead  ::)  so will pick up a pair of those at some point too.
just concerened about getting a pass at the mo.
least last nights greasing sorted that issue  ;D
Re: Any Guesses?
« Reply #42 on: 21 July 2009, 13:52:26 »
It should be 90510654
If WIM managed to adjust them then they should be pretty free now.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Any Guesses?
« Reply #43 on: 21 July 2009, 14:39:50 »
That should keep Ljay busy for an hour or two then.
Try not to ring your bell too much while she's doing the job mate.
Be a brave little soldier for a couple of hours.
 ;D ;D
TuBy's new whipping boy.
STMO999
Re: Any Guesses?
« Reply #44 on: 21 July 2009, 14:46:04 »
 ;D ;D
 ;D ;D ;D ;D
Sure she could manage a cuppa if she was coming in for advice.
Pages: 1 2 [3] 4 5 6   Go Up
