Author Topic: I just had to have it  (Read 1986 times)
KillerWatt
« on: 24 July 2009, 15:46:03 »
My mates reckon if I fell in to a barrel full of cocks, i'd still surface sucking on a tit.
3 litre MV6, 66,700 miles (history to prove), 1 former keeper.
It needs the usual bits (wishbones, droplinks, & backbox), but it has 11 months MOT and 7 months tax.
It has an intermittent fault where the gearbox drops in to limp mode occasionally, but switching off & restarting fixes that (it can only be a loose connection somewhere).
Other than that, everything else works.
Drove it away for £400.
Re: I just had to have it
« Reply #1 on: 24 July 2009, 15:51:22 »
Ex-Plod auto? About on the money to be honest if it is plod.
« Reply #2 on: 24 July 2009, 15:52:12 »
Gearbox is more likely to be mechanical than electrical, worth starting with atf fluid change though
« Reply #3 on: 24 July 2009, 15:52:42 »
Looks vaguely familiar... ;)
KillerWatt
« Reply #4 on: 24 July 2009, 15:53:16 »
It's the very same Kev  :y
« Reply #5 on: 24 July 2009, 15:53:51 »
Gearbox goes into limp reporting  the brake band solenoid circuit open IIRC.
« Reply #6 on: 24 July 2009, 15:55:09 »
Ah, thats a result.  Worth replacing solenoid when you change the fluid then :y
« Reply #7 on: 24 July 2009, 16:11:33 »
Can you direct me to that barrel, Killer? - need a change of fortune here.
« Reply #8 on: 24 July 2009, 16:16:15 »
Good price mate, I like it  :y
KillerWatt
« Reply #9 on: 24 July 2009, 17:36:34 »
3 fault codes came up Kev
P1625: Power Control Final Stage - Low Input
P1850: Shift Solenoid C - Circuit Open
P1850: Shift Solenoid C - Low Input
PS
To answer your question on the day.....Yes, you can manually change gear when it goes in to limp mode (so I'm guessing that proves the mechanics of the box work).
« Last Edit: 24 July 2009, 17:38:01 by KillerWatt »
KillerWatt
« Reply #10 on: 24 July 2009, 17:41:24 »
Yes it is ex-plod mate.
However, I will buy as many taxed & tested, year 2000 registered, ex-plods, in the same condition as this one, as you can find if I can have them at £400 each.
Bourne
  • Essex
  • Stupid tiny glovebox !
« Reply #11 on: 24 July 2009, 17:43:38 »
Good buy that! Reckon it could drive on water too with those jumbo tyres !
    • 530D M Sport, 330i Coupe
« Reply #12 on: 24 July 2009, 17:46:03 »
Pre-facelift Elite alloys, would have had steelies on in it's plod days
amigov6
« Reply #13 on: 24 July 2009, 19:52:29 »
I'm guessing it's auto but if the fault can be rectified reckon you've got a peachy Mig!!! :y
KillerWatt
« Reply #14 on: 24 July 2009, 20:35:56 »
If it is true "doom & gloom" (recon box), I'm not worried in the slightest because I know I'll pull the £400 back with ease.
Hell, the engine on it's own is £200 all day long (and that's the buyer removing it). Add the rest of it in the breaking stakes, and I'd probably end up showing a profit.
