Author Topic: V6 engine bay drawing  (Read 4425 times)
MartinP
  • Dudley
    • BMW 320D
« on: 20 February 2008, 21:47:39 »
Is there a drawing of the V6 engine bay, either PDF or CAD showing dimensions, position of mounting points.
I want to see if the 3.0 V6 will go into a Robin Hood kit car  ;)
Martin_1962
Re: V6 engine bay drawing
« Reply #1 on: 20 February 2008, 21:54:49 »
It is pretty compact and being a kit car you can bend things to make room.
My best advise is measure it
MartinP
  • Dudley
    • BMW 320D
« Reply #2 on: 20 February 2008, 22:16:34 »
Might just have to do that.
It would be nice to get a 200Bhp standard engine in a 700 Kg car  :y
« Reply #3 on: 20 February 2008, 22:37:43 »
I've wondered if it would fit in my Westfield several times. May just try it one day. :o
I would also say measure up as a first round, to see if it's a complete show stopper or a possibility, then maybe buy a ropey old engine just to try for size, or even a huge bit of polystyrene foam and cut it to shape.
I am aware of one Westfield with an x30xe in.
Check out the gearbox ratios carefully too. 1st gear looks rather short on the Omega's manual box (4. something:1) so I'd see if there's a closer ratio box that'll go on the engine.
There are lighter ways of getting 200 BHP (only slight tinkering with a C20XE willget you that) but a more peaky 200 BHP. Depends what you want.
Keep us updated :y
Jay w
  • Plymouth/Poole
  • omega gone
« Reply #4 on: 20 February 2008, 22:40:58 »
if a 2.0 XE will fit then there is a very good chance a V6 will
I fitted a V6 in a Mk2 cavalier, it went straight in and took up no more space than the XE then had come out. The only difference was that there was more space at the eng of the engine as the V6 is slightly less length
« Reply #5 on: 20 February 2008, 22:45:01 »
.. and start saving for a set of these....
MartinP
  • Dudley
    • BMW 320D
« Reply #6 on: 20 February 2008, 22:45:29 »
I might have to keep a few more bits for longer than I thought.
will have a good measure up after the cambelt party.
Minispud
  • Banbury, Oxfordshire
  • Ride hard with Passion
« Reply #7 on: 20 February 2008, 23:16:42 »
If Westfield can fit a Rover V8 into one of their cars, then a V6 into what is the same sort of car, should be no trouble, me's think  :-/ ::)
D.A.R.N.A Cycles.   Ride with Passion in your Heart
Martin_1962
« Reply #8 on: 20 February 2008, 23:29:04 »
Oh and have a look in the next issue of Practical Caravan and Caravan Magazine
MartinP
  • Dudley
    • BMW 320D
« Reply #9 on: 20 February 2008, 23:35:34 »
does it look like a goer?
Martin_1962
« Reply #10 on: 20 February 2008, 23:38:15 »
I hope so!
If I get panicky and want 50 you know what has happened ;D
Paulus
  • Wheaton Aston
  • Are you lookin' at me??? Punk???
« Reply #11 on: 22 February 2008, 12:33:40 »
You could model one on CAD...if you do, fire a copy my way  ;)
Growing old disgracefully...
« Reply #12 on: 22 February 2008, 12:43:52 »
Keep us updated :y
someone fit duratec V6 in westfield
http://www.reallyquick.co.uk/index.htm
http://www.reallyquick.co.uk/spec.htm
270 bhp 3.3 sec
« Last Edit: 22 February 2008, 12:46:03 by cem_devecioglu »
« Reply #13 on: 22 February 2008, 13:08:46 »
Keep us updated :y
270 bhp 3.3 sec
Nice. 270 BHP from the original cams too.
Shows how restrictive Ford's typical intake setup is. Torque peaks at quite high RPM, thanks to the short intake tract I guess, but that's hardly an issue in a Wesrtfield.
« Reply #14 on: 22 February 2008, 14:53:51 »
Its a different beast (SEight), bigger tub, stronger chassis the works.
On the V6, you have to think how big a 4 pot is with inlet and exhaust manifolds....and the GM V6 is a compact version (54deg not 60deg)...
Page created in 0.023 seconds with 16 queries.
